- pH-neutral de-ironizer
- Easily removes stubborn brake dust
- Perfect for removing fallout rust
- Turns purple
The Dodo Juice Ferrous Dueller is a pH-neutral fallout remover that safely removes stubborn metal particles from your car. Whether it’s brake dust on wheels, rail dust on the paint, or iron deposits on windows, Ferrous Dueller cleans the surface and protects it from damage this contamination can cause over time.
During use, the product changes color to purple or red wherever it comes into contact with iron particles, letting you see exactly where it’s working. Its slightly thicker formula adheres well to vertical surfaces, giving it more time to work, while extra active ingredients make the result cleaner than similar products. Dodo Juice has kept the scent of this type of cleaner to a minimum, so you won’t encounter strong or fruity smells.
For best results, use Ferrous Dueller on a cool surface out of direct sunlight. While it takes over much of the work of a clay treatment, a true clay may still be needed for a full deep clean. Always test first on a small area for sensitive paint or wheels, and rinse off with water after a few minutes.
Ferrous Dueller is suitable for wheels, paint, glass, and unpainted plastic or rubber. With this product, you remove iron particles thoroughly, safely, and visibly, leaving your car looking clean and sharp again.
| Product number: | DJFD500 |
| Consistency: | Liquid |
- Thoroughly wash your car first and rinse away loose dirt, dust, and sand. The surface should be clean and cool, out of direct sunlight, so the product can work optimally.
- Apply a small amount to an inconspicuous area of paint, wheel, or plastic to check for any unwanted reactions.
- Spray Ferrous Dueller evenly onto the surface to be treated. The product will turn purple or red upon contact with iron particles. This is a normal reaction and indicates that it’s working.
- Let it work Allow the product to sit for a few minutes. On vertical surfaces or stubborn contamination, you can gently work it in with a soft brush or microfiber cloth to enhance its effect.
- Rinse Rinse the surface thoroughly with water until all residues and loosened iron particles are removed.
- Aftercare Inspect the surface and repeat the treatment on areas where contamination is still visible. After rinsing, a clay treatment can be performed if desired for a fully smooth and clean surface.
Het verwijdert hardnekkige metaaldeeltjes zoals remstof, spoorslag en ijzerdeeltjes van velgen, lak, glas en ongeverfde kunststofdelen, zodat oppervlakken schoon blijven en schade wordt voorkomen.
Tijdens gebruik verkleurt Ferrous Dueller paars of rood op de plekken waar het ijzerdeeltjes oplost. Dit is een normale reactie en laat zien dat het product actief is.
Het kan veel van het werk van een claybar overnemen, maar voor een volledige dieptereiniging kan een claybehandeling nog steeds nodig zijn.
Draag altijd handschoenen en oogbescherming. Vermijd contact met huid en ogen en adem de spuitnevel niet in.
Ja, het is pH-neutraal en veilig voor lak, glas, velgen en kunststof. Test altijd eerst op een klein stukje bij gevoelige of onbekende oppervlakken.
Nee, gebruik het alleen op koele oppervlakken en uit direct zonlicht. Zo droogt het niet te snel op en werkt het optimaal.
4 - 3 of 18 reviews
Tevreden
Simpelweg zoals bijna alle dodo juice producten tevreden van
Doet wat het moet doen
Even opspraaien en dan word het paars. Even met een spons en weg is het remstof
goed spul
Ik ben er zeer tevreden mee.
