Detail Wheel Brush Large
- Cleans deep wheel barrels
- Flexible coated stem
- Safe Memory-Nylex bristles
- Chemical resistant design
EZ Detail EZ Detail Brush Large - The ultimate wheel brush
The EZ Detail Brush Large is the bigger brother of the Mini and sets the global standard for safe and effective wheel cleaning. This brush is specifically designed to reach deep into wheel barrels and remove stubborn brake dust and dirt without scratching. Thanks to the long, flexible stem, the brush effortlessly reaches behind spokes and between brake calipers, areas unreachable with a wash mitt.
The special Memory-Nylex bristles are gentle on all wheel finishes, from painted to chrome-plated aluminum. These bristles are resistant to powerful wheel cleaners and always return to their original shape when exposed to heat. The stem and tip are fully coated with rubber, ensuring no metal comes into contact with the vehicle. Its size also makes this brush excellent for cleaning engine bays, wheel wells, and exhaust tips.
| Product number: | EZ-BRUSH-L |
- Total length: 45 cm
- Brush length: 23 cm
- Length of the nylon hair: 5 cm
Mix a wheel cleaner or car shampoo with water in a bucket.
Immerse the brush in the soapy water to ensure proper lubrication.
Gently move the brush between spokes and into wheel barrels.
Rinse the brush frequently in the bucket to release trapped dirt.
Thoroughly rinse both the surface and the brush with clean water after cleaning.
Hang the brush to dry; the bristles will regain their original shape.
Tips
Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
30 - 3 of 100 reviews
Teleurstellend
Voor mij de uitkomst, aangezien ik zijn grotere broertje slecht (lees: niet zonder slijtage) tussen de ankerplaten en het velgbed kon krijgen. Werkt helemaal top, en kan overal bij, heb hem nu zo'n 3 maanden en gebruik hem wekelijks op meerdere auto's, ziet er nog helemaal nieuw uit.
Op zich prima werkende borstel op de degelijkheid na. Sluit me wat dat betreft aan bij Wim Claessen, stang breekt af binnen korte periode na aanschaf.
Fantastisch
Aangeschaft omdat toch een hoop mensen positief waren hierover. Gisteren uitgeprobeerd en het werkt prima! Wel vind ik de borstel wat 'goedkoop' aanvoelen, echt fijn vasthouden kun je hem niet.
