Detail Wheel Brush Large
Art. nr. EZ-BRUSH-L
EZ Detail EZ Detail Brush Large - The ultimate wheel brush
The EZ Detail Brush Large is the bigger brother of the Mini and sets the global standard for safe and effective wheel cleaning. This brush is specifically designed to reach deep into wheel barrels and remove stubborn brake dust and dirt without scratching. Thanks to the long, flexible stem, the brush effortlessly reaches behind spokes and between brake calipers, areas unreachable with a wash mitt.
The special Memory-Nylex bristles are gentle on all wheel finishes, from painted to chrome-plated aluminum. These bristles are resistant to powerful wheel cleaners and always return to their original shape when exposed to heat. The stem and tip are fully coated with rubber, ensuring no metal comes into contact with the vehicle. Its size also makes this brush excellent for cleaning engine bays, wheel wells, and exhaust tips.
Product number: EZ-BRUSH-L
  • Total length: 45 cm
  • Brush length: 23 cm
  • Length of the nylon hair: 5 cm
  1. Mix a wheel cleaner or car shampoo with water in a bucket.
  2. Immerse the brush in the soapy water to ensure proper lubrication.
  3. Gently move the brush between spokes and into wheel barrels.
  4. Rinse the brush frequently in the bucket to release trapped dirt.
  5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
  6. Hang the brush to dry; the bristles will regain their original shape.
Tips
  • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
  • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Excellent wheel brush: soft yet effective, reaches deep between spokes and behind the rim, durable and easy to clean. Ideal for detailers and tight spaces, works well with wheel cleaners; worth the price despite some splatter and occasional handle wear.
34 - 3 of 102 reviews
Topkeuze
Super, komt helemaal achterin en achter de spaken. Eenvoudig klusje nu die wielen schoonmaken! Spettert, maar dat doen ze allemaal. Degelijke kwaliteit, even in een bak met heet water en de borstel is als nieuw. Ik bewaar hem wel in de originele verpakking; zo blijft ie heel.
Tinus - 24/08/2008
Acceptabel
Een ideale borstel om de velgen te reinigen! Echt super, hij komt makkelijk in alle hoekjes en gaten, en ook bij grote remschijven is het - eindelijk - makkelijk de velgen geheel te reinigen. Ook handig voor het reinigen van de wielkasten. Aanrader!
Sven - 01/08/2008
Zeer handige velgen reiniger. Alleen is hij naar mijn inzicht iets te zacht. Spettervrij is hij zeer zekers niet. Maar voldoet aan de eisen die er aan gesteld worden.
Nor - 31/07/2008
