Detail Wheel Brush Large
Art. nr. EZ-BRUSH-L
EZ Detail EZ Detail Brush Large - The ultimate wheel brush
The EZ Detail Brush Large is the bigger brother of the Mini and sets the global standard for safe and effective wheel cleaning. This brush is specifically designed to reach deep into wheel barrels and remove stubborn brake dust and dirt without scratching. Thanks to the long, flexible stem, the brush effortlessly reaches behind spokes and between brake calipers, areas unreachable with a wash mitt.
The special Memory-Nylex bristles are gentle on all wheel finishes, from painted to chrome-plated aluminum. These bristles are resistant to powerful wheel cleaners and always return to their original shape when exposed to heat. The stem and tip are fully coated with rubber, ensuring no metal comes into contact with the vehicle. Its size also makes this brush excellent for cleaning engine bays, wheel wells, and exhaust tips.
Product number: EZ-BRUSH-L
  • Total length: 45 cm
  • Brush length: 23 cm
  • Length of the nylon hair: 5 cm
  1. Mix a wheel cleaner or car shampoo with water in a bucket.
  2. Immerse the brush in the soapy water to ensure proper lubrication.
  3. Gently move the brush between spokes and into wheel barrels.
  4. Rinse the brush frequently in the bucket to release trapped dirt.
  5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
  6. Hang the brush to dry; the bristles will regain their original shape.
Tips
  • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
  • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
32 - 3 of 100 reviews
Zeer handige borstel, de kwaliteit van de haren is ook zeer goed! Maar het handvat is een stukje triestiger. Dit is gewoon vaan hout en na enkele keren te gebruiken komt de stang los uit het handvat!
Dhr. Wim Claessen - 21/11/2010
Hele fijen velgenborstel. Flexibel, dik en toch zacht. Vooralsnog roest hij niet.
Dhr. Benjamin Mulder - 15/11/2010
Topkeuze
zeer fijne borstel voor de wielen gaat lang mee en wordt zacht bij warm water en hard bij koud water heb hem nu al verschillende malen gebruikt en ben er zeer tevreden over, haren blijven netjes staan en valt niet uit elkaar.
Silence - 08/08/2009
