Glides like a pro
Ultra-smooth lubrication
Gyeon Q²M ClayLube is specially designed to make the claying process as smooth as possible. Thanks to its ultra-low friction between the clay and the surface, the risk of marring and other paint defects is minimized. The formula ensures that the clay effortlessly glides over the paint, allowing you to work with less pressure and effort. This not only makes it more pleasant to use but also safer for your vehicle’s paint. Whether you use a soft or medium clay bar, this lube always provides the perfect lubrication.
Less hassle, more results
Faster and more effective claying
With Gyeon Q²M ClayLube, you remove stubborn contamination in less time and with less effort. Because the clay moves smoothly over the paint without sticking, you work faster and more efficiently. This means fewer interruptions and consistently better results. Ideal for both professionals and detailing enthusiasts who want to optimize their workflow without compromising on quality. Thanks to its enhanced glide properties, the clay also lasts longer, meaning you won’t need to replace it as often.
More coverage with less product
Economical and effective
One of the biggest advantages of Gyeon Q²M ClayLube is its impressive efficiency. Its concentrated formula requires only a thin layer to provide optimal lubrication, meaning you use less product per detailing session. Additionally, ClayLube is dilutable, allowing you to adjust its strength depending on the level of contamination. This makes it not only a smart choice for your paint but also for your wallet. More claying, less waste!
Gyeon Q²M ClayLube ensures a faster, safer, and more effective claying process. Simply spray on, clay, and rinse off (preferably with high pressure). If Q²M ClayLube dries, simply wash the area with a mild soapy solution, such as Q²M Bathe. Then dry the surface.
| Product number | GYCLA05 |
| Product form | Lubricant |
Super!
Heel fijne clay lube en heel zuinig in gebruik als je weet dat je hem kan verdunnen tot 1:10. Gebruik deze clay lube samen met de bilthammer klei en dit werkt fantastisch.
Fijne lube
Werkt fijn maar is niet echt zuinig in gebruik. Er zijn andere lubes net een betere prijs kwaliteit verhouding. Daarom 4 sterren.
Zeeer fijne spray. beter verdun je dit wel want anders vlieg je er wel erg snel door. Ik gebruik hem 1 op 2.
