Wheels in Top Shape
Powerful Cleaning
The Gyeon Q²M Iron WheelCleaner is an advanced wheel cleaner specifically designed to effortlessly remove stubborn dirt and brake dust. Thanks to its unique formula, the cleaner effectively adheres to contaminants and breaks them down without damaging the wheel. The cleaner changes color as it works, allowing you to see exactly where it is active. This makes it an essential product for car enthusiasts who want to keep their wheels in top condition without using aggressive chemicals.
No Wheel Left Behind
Universal Compatibility
Whether you have polished, matte, or painted wheels, the Gyeon Q²M Iron WheelCleaner is suitable for all types of wheels and finishes. Its pH-neutral formula ensures that even delicate surfaces can be cleaned safely without the risk of discoloration or damage. This makes it a reliable choice for anyone looking to maintain their wheels professionally, regardless of the material or coating.
Brake Dust? Not a Chance
Deep Cleaning
Brake dust and stubborn road grime can settle deep into the pores of your wheels, but with Gyeon Q²M Iron WheelCleaner, this problem is easily solved. The powerful formula breaks down iron particles and lifts dirt effectively from the surface, leaving your wheels looking as good as new. This not only ensures a brilliant shine but also helps prevent corrosion and damage caused by accumulated dirt.
The Gyeon Q²M Iron WheelCleaner is a special and highly effective cleaner for all types of wheels and finishes. The Iron WheelCleaner is formulated with a powerful formula to efficiently remove dirt and brake dust.
The Q²M Iron WheelCleaner ensures you get the most out of your wheel washing routine. The cleaner has a gel-like consistency, allowing it to adhere excellently to the surface, loosening and dissolving dirt particles. The "IRON" in the name signifies its strong ability to remove iron deposits without losing the typical wheel-cleaning characteristics of the product. The Iron WheelCleaner is a powerful cleaner, yet safe for all types of rims and finishes, whether coated or uncoated. The formula makes it an ideal solution for cleaning and maintaining wheels without any risk of damaging the finish.
| Product number | GY-IWC-1000 |
| Acid-free | Yes |
| Additives | Iron remover |
| Cleaning power | Strong |
| Colors Purple | Yes |
- Always use the Q²M Iron WheelCleaner on a cooled wheel and avoid direct sunlight
- Spray the Iron WheelCleaner generously on the wheel and brake caliper
- Allow it to sit for 1 to 2 minutes before rinsing the wheel thoroughly
- For even more cleaning power, you can apply the Q²M Iron WheelCleaner with your favorite wheel brush or mitt
Fijne iron
Erg fijn spul wat niet extreem stinkt naar rotte eieren
Werkt goed, alleen mindere sproeier
Product is erg fijn in gebruik! Er komt een fijne spray uit en het maakt erg goed schoon!
Voor mij het enige minpuntje is dat de sproeier soms een beetje na-druppelt, waardoor je het wel eens op je handen kunt krijgen. Sowieso handschoenen aantrekken!
Gebruik dit produkt al enkele jaren en nog steeds tevreden.
