All-in-one for inside and out
Formula for inside and out
Meguiar's Paint, Dash & Glass Cleaner is the perfect all-in-one solution for both interior and exterior applications. Whether you're cleaning the exterior of your car or maintaining the interior, this versatile formula is suitable for cleaning the bodywork as well as the dashboard. It provides deep cleaning without damaging the surface, while also offering the necessary protection for a glossy finish. Thanks to innovative technology, you can use this cleaner on various surfaces, from glass to plastic and even metal parts, without worrying about streaks or marks.
All-in-One
Cleaning, protection, and care in one
Meguiar's Paint, Dash & Glass Cleaner is not only designed to thoroughly clean surfaces, but also to protect and maintain them. The formula effectively removes dirt, dust, and stains, while simultaneously applying a protective layer that prevents dirt from reattaching. This ensures your car looks clean and well-maintained for longer, while also extending the lifespan of the surface. It is the ideal choice for those who want to maintain their car and protect the finish from future contaminants.
Quick care in a flash
Fast maintenance for busy days
With Meguiar's Paint, Dash & Glass Cleaner, you're guaranteed quick and easy care for your vehicle. The user-friendly spray bottle makes application and buffing simple, even for those with little time. The product is perfect for a quick touch-up between full washes, ensuring your car always looks fresh. Thanks to the efficient formula, you don’t need to spend hours on details; the results are instantly visible, making it perfect for the modern, busy car owner.
Introducing the all-in-one solution for both the interior and exterior of your car! This detailer spray effortlessly removes dust, fingerprints, bird droppings, and other contaminants while leaving behind a protective, non-greasy layer. Safe to use on paint, plastic, trim, vinyl, leather, glass, and even navigation screens. In short, one product for all your cleaning needs!
Key Features:
- Versatile for both interior and exterior use.
- Safe on all surfaces.
- Thoroughly cleans and provides light protection.
- Simple and quick to use.
With a 709 ml bottle, you have enough product to make your whole car shine. Don’t miss this must-have for any car enthusiast who loves a fresh and clean ride!
| Product number | G250224 |
| Additional features | Cleansing, Protective |
| Suitable for | Glass, Interior, Paintwork, Touchscreens |
- Shake the bottle well before use.
- Spray the product directly onto the surface to be cleaned or onto a clean microfiber cloth.
- Wipe the surface clean with the cloth, ensuring all dirt is removed.
- Use a dry microfiber cloth to buff for a streak-free finish.
- Repeat if necessary for stubborn dirt.
Note: Do not use on surfaces where a slick result is undesirable, such as steering wheels or pedals.
Heerlijk
Fijne allround detailspray voor alle oppervlakken en die ook nog heerlijk ruikt! Verpakt in een grote fles met fraaie spray kop , van een premium merk en ook nog voor een attractieve prijs! Top!
Toch jammer...
Een alleskunner. Ik zou er geen ander woord voor hebben. Uw glas, plastic, screens, navigatie, verwijderen van de poep, stof, tja wat niet. Het is denk ik zelfs te gebruiken als lubricant bij Kleien. Een enorme fles en een pad of doek en je kunt de auto te lijf gaan om de viezigheid schoon te maken. Maar toch vind ik het jammer. Als hier nou gelijk wax of sealant in zat heb je eigenlijk maar 1 fles nodig. Zo'n feest is het niet, maar een alleskunner is het zeker. Snel bijwerken of schoonmaken met een prima resultaat
Top spul.
Goed spul.
Laat geen vlekken of strepen na.
