Loosen it up
Safely removing dirt
Monello Artico Magico is specially formulated to safely loosen stubborn dirt without the need for immediate washing or scrubbing. Thanks to its advanced formula, the foam clings to the surface of your vehicle, actively working to break down grime and contaminants. This allows you to rinse away a large amount of dirt before making contact with the paint, significantly reducing the risk of wash-induced scratches. It’s the ideal first step in a safe and effective wash routine, perfect for anyone who wants to keep their paintwork in pristine condition.
Foam party
A thick foam blanket
What stands out immediately with Artico Magico is the rich, thick foam it produces. Whether you're using a foam cannon or a manual foamer, the foam clings beautifully to the vehicle’s surface. It sticks around long enough to work on dirt while also delivering that satisfying, dramatic look we all love. Not only is it highly effective, it’s just fun to use. The dense foam also acts as a cushion between the dirt and your paint, helping to prevent scratches during the wash process.
No strip show
Safe for wax, sealants and coatings
A good snow foam should tackle dirt without removing your protection, and that’s exactly what Artico Magico does. This pH-neutral formula is safe to use on vehicles treated with wax, sealants or ceramic coatings. You won’t have to worry about stripping away your carefully applied protection during the pre-wash stage. It cleans thoroughly without reducing the hydrophobic performance of your surface, making it perfect for regular maintenance. Your car stays clean and your protection stays intact.
The Artico Magico snow foam from Monello is a PH-neutral foam that allows you to safely pre-wash vehicles. This makes the Artico Magio suitable for all surfaces, including matted surfaces and car wraps. The snow foam is also safe for any wax or sealant. With the Artico Magico, you create a nice, thick layer of foam that safely loosens dirt without having to touch your vehicle. The result is a vehicle that is free of coarse dirt.
The Artico Magico works best with a foam lance and a pressure washer. You simply spray the foam onto the vehicle in an up and down motion. Allow the product to soak in and rinse thoroughly. After this treatment, your vehicle is ready for a wash.
| Product number | MMF0150 |
| Cleaning power | Mild, Normal |
| Concentration | Concentrate |
| Gloss Level of Surface | Glossy, Matte, Satin Finish |
| Volume | Extra large (more than 2L) |
- Foam the vehicle with lance and high-pressure cleaner
- Allow the product to work in well, do not let the product dry on the car
- Rinse the vehicle thoroughly
Fijn spul
Fijne pre wash die niet mijn wax stript maar wel het vuil los weekt
Tevreden na aankoop
Frisse geur bij het inzepen van de wagen, maakt een mooi schuimdeken op de wagen.
Ik kocht de 5L verpakking dus ik kan nog wel even verder :)
lekker spul
Lekker spul. Best een mooi schuim deken. Zelfs met gebruik met een handpomp.
Even laten inwerken en dan afspoelen. Het wassen hierna met Dodo Juice shampoo een stuk makkelijker.
