Artico Magico Snow Foam - 5000ml
Art. nr. MMF0150
4.6 (87)
  • Foam with a purpose
    The perfect pre-wash
Loosen it up
Safely removing dirt
Monello Artico Magico is specially formulated to safely loosen stubborn dirt without the need for immediate washing or scrubbing. Thanks to its advanced formula, the foam clings to the surface of your vehicle, actively working to break down grime and contaminants. This allows you to rinse away a large amount of dirt before making contact with the paint, significantly reducing the risk of wash-induced scratches. It’s the ideal first step in a safe and effective wash routine, perfect for anyone who wants to keep their paintwork in pristine condition.
Foam party
A thick foam blanket
What stands out immediately with Artico Magico is the rich, thick foam it produces. Whether you're using a foam cannon or a manual foamer, the foam clings beautifully to the vehicle’s surface. It sticks around long enough to work on dirt while also delivering that satisfying, dramatic look we all love. Not only is it highly effective, it’s just fun to use. The dense foam also acts as a cushion between the dirt and your paint, helping to prevent scratches during the wash process.
No strip show
Safe for wax, sealants and coatings
A good snow foam should tackle dirt without removing your protection, and that’s exactly what Artico Magico does. This pH-neutral formula is safe to use on vehicles treated with wax, sealants or ceramic coatings. You won’t have to worry about stripping away your carefully applied protection during the pre-wash stage. It cleans thoroughly without reducing the hydrophobic performance of your surface, making it perfect for regular maintenance. Your car stays clean and your protection stays intact.
The Artico Magico snow foam from Monello is a PH-neutral foam that allows you to safely pre-wash vehicles. This makes the Artico Magio suitable for all surfaces, including matted surfaces and car wraps. The snow foam is also safe for any wax or sealant. With the Artico Magico, you create a nice, thick layer of foam that safely loosens dirt without having to touch your vehicle. The result is a vehicle that is free of coarse dirt.
The Artico Magico works best with a foam lance and a pressure washer. You simply spray the foam onto the vehicle in an up and down motion. Allow the product to soak in and rinse thoroughly. After this treatment, your vehicle is ready for a wash.
Product number MMF0150
Cleaning power Mild, Normal
Concentration Concentrate
Gloss Level of Surface Glossy, Matte, Satin Finish
Volume Extra large (more than 2L)
pH value Neutral (pH 6 - 8)
  • Foam the vehicle with lance and high-pressure cleaner
  • Allow the product to work in well, do not let the product dry on the car
  • Rinse the vehicle thoroughly
Yes, Artico Magico is pH-neutral and safe for wax layers, sealants, matte paint, and wraps. This means you can pre-wash with confidence without affecting your protection.
Met een halve liter concentraat kun je ongeveer 5 tot 6 auto's doen, afhankelijk van hoe sterk je mengt. Gebruik je 1:10, dan haal je er zelfs meer uit. Het hangt ook af van je foamlans en hoe royaal je sprayt.
Voor lichte vervuiling gebruik je een verhouding van 1:10 (1 deel product, 10 delen water). Is je auto echt vies? Ga dan voor 1:4 voor een krachtigere schuimlaag.
Zeker! Artico Magico is veilig voor matte lakken, satijnen finishes én car wraps. Geen risico op glansvorming of vlekken.
H315: Causes skin irritation.
Corrosion: Corrosive
Fantastisch
Top spul ! Reinigt gewoon heel erg goed! Tip; koop er een goeie Foamlens bij (die van Monello) en zorg dat je er een Tapkraan bij neemt. Zonder Tapkraan is het een gesmeer van niks.
Sander H. - 1 August 2014
Geweldig
De foam aangebracht met de Gloria Foammaster FM10. Zowel met de mengverhouding 1:4 als 1:10 komt er mooi dik schuim uit wat mooi op de auto blijft liggen. Het schuim ruikt redelijk sterk maar wel fris. Na het afspoelen van het schuim is het hardnekkige vuil wat nog aanwezig op de auto, zeer makkelijk weg te poetsen. Zeer tevreden over dit product dus.
Jakob - 2 July 2014
Mooi schuim, gaat lang mee, auto is heel proper!
Dit is voor mij een topproduct, eerste keer dat ik met foam werk en direct raak!
Ik zal later nog andere foams uitproberen om het verschil te testen. Voorlopig geef ik hem 5/5!
Lawrence Devroey - 16 June 2014
