On Whit Monday (May 25th) we will be closed for the day.
Monello Lancia Foam Lance - Karcher K-series
Art. nr. MLKARC
The Monello Lancia Foam Lance is the improved foam lance, now even more robust, stable, and larger.
The Lancia produces thicker foam, making it even better at safely loosening dirt without needing to touch the vehicle. This greatly reduces the risk of creating wash scratches. Another benefit of the thicker foam is that you’ll use less shampoo per wash, making each cleaning session more efficient and cost-effective.
The Monello Lancia Foam Lance now comes with an HDPE mixing bottle instead of the well-known PET version.
The advantages of this change are clear: the HDPE bottle is tear-resistant and more resistant to acids and salts. It’s also more stable, meaning it won’t tip over easily when top-heavy. The Lancia 2.0 bottle has a capacity of 1000ml and features a 10-step scale on the back, making it easy to measure and mix your desired ratios.
The foam lance comes with both a 1.1mm and 1.25mm nozzle.
Thanks to the new attachment system, switching between nozzles is quick and simple. The improved adjustment knob at the front of the spray head allows you to change the spray pattern both horizontally and vertically, making foam application even easier. The top adjustment dial lets you control the foam mix ratio.
For the Monello Pistola Corta, you’ll need a Quick Release Type 3 connector.
An additional charge applies for the AVA connector.
Note:
If you're unsure which connector you need, compare the size of your current pressure washer attachments with the connectors listed in the overview. The measurements are provided for reference.
Please keep in mind that some pressure washer brands offer three or more different types of connections—even within the same brand.
Still not sure? Send us an email with a clear photo of your attachment so we can help you find the right fit.
Product number: MLKARC
  • Inhoud fles: 1000ml
  • Geleverd met 1.1 en 1.25 mm sproeiers
  • 360° functie
  • Verkrijgbaar voor vrijwel elke hogedrukreiniger
  • The Lancia Foam Lance comes pre-installed with a 1.1 mm nozzle. If your pressure washer shuts off or stalls, switch to the included 1.25 mm nozzle. This can easily be done with a flathead screwdriver. You can see how to do this in the video below:
    Changing the nozzle
  • Screw the chosen connector onto the foam lance. Hand-tight is sufficient. Depending on the connector used, make sure the wings are in the correct position so that the lance sits straight on the spray gun.
  • Attach the included pickup tube under the red cap. This will draw the liquid during foaming.
  • Fill the bottle with your foam mixture in the correct ratio, and use warm water for better blending.
  • After use, rinse thoroughly with clean water. Remove the bottle and run clean water through the lance for at least 30 seconds to flush the internal filter.
Ja. De meshfilters zorgen voor het mengen van water, lucht en product om schuim te maken. Na verloop van tijd kunnen ze verstopt raken door residu, en dan kun je ze eenvoudig vervangen. Los verkrijgbaar.
Zeker. We hebben losse HDPE-flessen beschikbaar, zelfs met een dop zodat je mengsel schoon en lekvrij bewaard blijft.
Ja, alle foams werken met deze lans. De HDPE-fles is bestand tegen vrijwel alle reinigingsmiddelen en gaat veel langer mee dan PET-flessen.
  1. Een HDPE-fles (stevig, zuur- en zoutbestendig, scheurt niet)
  2. Betere stabiliteit, zodat hij niet snel omvalt
  3. Eenvoudig verstelbare straal (horizontaal of verticaal)
  4. Instelbare mengverhouding met de knop bovenop
1 - 3 of 43 reviews
Top foam lance
Zeer handig in combinatie met mijn karcher. Even zoeken naar de juiste afstelling om de juiste combinatie water/schuim te bekomen maar verder loopt alles vlot. Zeer tevreden van deze aankoop
Tommy - 11/05/2026
Top foam lance
Echt een top ding, je kan m heel goed afstellen met een brede of smalle foam dekking. Is van goed sterk materiaal gemaakt en ziet er zeer degelijk uit. Wat een upgrade van mijn Kärcher foam gun. In samenwerking met de monello pistola een perfecte combi en zeer goede upgrade om je wagen wekelijks goed te wassen.
Sander - 08/04/2026
Top foamlance, juiste afstelling nodig
Op mijn Kärcher K7 is de druk wat te hoog, waardoor het schuim meer melkachtig wordt. Met een minder krachtige Kärcher krijg je juist mooi dik foam. Ik moest de grotere sproeier monteren omdat de Kärcher anders in de beveiliging ging. Over het geheel ben ik zeer tevreden, werkt goed en voelt degelijk.
Jeroen - 06/04/2026
  • Let your car disappear with a thick foam layer
    Foam canon
Fits your setup
Available with multiple connectors
The Monello Lancia Foam Lance is available with a wide range of connectors, making it compatible with almost any pressure washer. Whether you’re using a Kärcher K-Series, Nilfisk, Kränzle, Bosch or another popular brand, there’s a version that fits your machine perfectly. No need to struggle with universal fittings or complicated adapters—just choose the version that matches your setup and you’re good to go. Simple, efficient, and tailored to your detailing gear.
Foam party alert
Thick and clingy foam
What really sets this foam lance apart is the impressively thick foam it produces. By precisely mixing air, water and shampoo, it creates a creamy lather that clings to your vehicle’s surface. This helps to effectively loosen dirt and grime before you even touch the paint with a wash mitt. A proper pre-wash starts with a rich foam layer, and that’s exactly what the Monello Lancia delivers. It’s not just more effective—it also makes washing your car way more fun.
Tough and clever
Durable 1L bottle with measurements
The included 1-liter HDPE bottle is not only tough, but also cleverly designed. With a clear measurement scale on the side, it allows you to easily and accurately mix the right shampoo-to-water ratio. This helps avoid waste and ensures optimal foam every time. Made from high-quality HDPE material, the bottle is built to withstand strong chemicals and frequent use. Whether you're working with heavy-duty foams or gentle shampoos, this bottle is ready for the job.
Service producten
Lege fles met dop voor Monello Lancia Foam Lance
  • Semi-transparent
  • HDPE bottle
  • Contains convenient measuring scale
  • Wide filling opening
€ 7.99
Temporarily unavailable
Get stock notification
Lancia 2.0 Mesh filter
  • Replacement filter
  • Handy to have as a spare filter
€ 5.99
Nearly sold out
Lancia 2.0 Connector aansluiting
  • Replacement connector
€ 9.99
Last chance
Dodo Juice
Snow Commotion Snow Foam Cannon
  • Foamlans voor hogedrukreinigers
  • Op meerdere manieren instelbaar
  • Met snelsluiting
  • Inclusief stevige 1L-fles
  • Met Kärcher K-series connector
  • Professionele kwaliteit
€ 57.99
Has been discontinued
AVA
Premium Foam Cannon Bundle
  • Premium foamlans
  • Geleverd met 3 bekers en 2 deksels
  • Meerdere maatverdelingen
€ 69.99
Last chance
AVA
Premium Foam Cannon
  • Premium foam cannon
  • Geleverd met brede 600 ml beker
  • Ook voor de meeste liter en halve liter flessen foam
  • Gemakkelijk in te stellen
€ 39.99
