The Monello Lancia Foam Lance is the improved foam lance, now even more robust, stable, and larger.
The Lancia produces thicker foam, making it even better at safely loosening dirt without needing to touch the vehicle. This greatly reduces the risk of creating wash scratches. Another benefit of the thicker foam is that you’ll use less shampoo per wash, making each cleaning session more efficient and cost-effective.
The Monello Lancia Foam Lance now comes with an HDPE mixing bottle instead of the well-known PET version.
The advantages of this change are clear: the HDPE bottle is tear-resistant and more resistant to acids and salts. It’s also more stable, meaning it won’t tip over easily when top-heavy. The Lancia 2.0 bottle has a capacity of 1000ml and features a 10-step scale on the back, making it easy to measure and mix your desired ratios.
The foam lance comes with both a 1.1mm and 1.25mm nozzle.
Thanks to the new attachment system, switching between nozzles is quick and simple. The improved adjustment knob at the front of the spray head allows you to change the spray pattern both horizontally and vertically, making foam application even easier. The top adjustment dial lets you control the foam mix ratio.
For the Monello Pistola Corta, you’ll need a Quick Release Type 3 connector.
An additional charge applies for the AVA connector.
Note:
If you're unsure which connector you need, compare the size of your current pressure washer attachments with the connectors listed in the overview. The measurements are provided for reference.
Please keep in mind that some pressure washer brands offer three or more different types of connections—even within the same brand.
Still not sure? Send us an email with a clear photo of your attachment so we can help you find the right fit.
| Product number: | MLKARC |
- Inhoud fles: 1000ml
- Geleverd met 1.1 en 1.25 mm sproeiers
- 360° functie
- Verkrijgbaar voor vrijwel elke hogedrukreiniger
- The Lancia Foam Lance comes pre-installed with a 1.1 mm nozzle. If your pressure washer shuts off or stalls, switch to the included 1.25 mm nozzle. This can easily be done with a flathead screwdriver. You can see how to do this in the video below:
Changing the nozzle - Screw the chosen connector onto the foam lance. Hand-tight is sufficient. Depending on the connector used, make sure the wings are in the correct position so that the lance sits straight on the spray gun.
- Attach the included pickup tube under the red cap. This will draw the liquid during foaming.
- Fill the bottle with your foam mixture in the correct ratio, and use warm water for better blending.
- After use, rinse thoroughly with clean water. Remove the bottle and run clean water through the lance for at least 30 seconds to flush the internal filter.
Ja. De meshfilters zorgen voor het mengen van water, lucht en product om schuim te maken. Na verloop van tijd kunnen ze verstopt raken door residu, en dan kun je ze eenvoudig vervangen. Los verkrijgbaar.
Zeker. We hebben losse HDPE-flessen beschikbaar, zelfs met een dop zodat je mengsel schoon en lekvrij bewaard blijft.
Ja, alle foams werken met deze lans. De HDPE-fles is bestand tegen vrijwel alle reinigingsmiddelen en gaat veel langer mee dan PET-flessen.
- Een HDPE-fles (stevig, zuur- en zoutbestendig, scheurt niet)
- Betere stabiliteit, zodat hij niet snel omvalt
- Eenvoudig verstelbare straal (horizontaal of verticaal)
- Instelbare mengverhouding met de knop bovenop
Log in
2 - 3 of 43 reviews
Beste van het beste
Ja, die van AVA geeft ook geweldig goed schuim, maar allround is deze het beste. Te beginnen bij de brede beker waardoor die niet snel zal omvallen. Verder is het bijna onmogelijk dat hij niet passend is voor jouw hogedrukreiniger met alle opties die ze aanbieden. Dan het schuim, je kunt het gerust gebruiken als scheerschuim als je het mij vraagt. En als je dat liever niet hebt, kun je de schuimtoevoer ook nog eens instellen. Ik kan niet zonder.
Wat een schuim!
Nadat mijn vorige foamlans het steeds slechter ging doen heb ik deze besteld. Wat een verschil! Zoveel schuim heb ik met die vorige nooit gehad. Ik heb hem pas 1 keer gebruikt, toen vond ik hem zeker niet zuinig. Mogelijk moet ik nog wat uitproberen met de instellingen. In ieder geval ben ik erg tevreden.
Topkwaliteit
Hiervoor had ik de mccj foam gun die ook goed aangeschreven staat. Deze monello overstijgt die zeker qua kwaliteit. Erg handig om 1 of 2 lege bekers bij te bestellen. Icm de short trigger gun met quick release koppeling gaat het detailen echt een stuk sneller.
Fits your setup
Available with multiple connectors
The Monello Lancia Foam Lance is available with a wide range of connectors, making it compatible with almost any pressure washer. Whether you’re using a Kärcher K-Series, Nilfisk, Kränzle, Bosch or another popular brand, there’s a version that fits your machine perfectly. No need to struggle with universal fittings or complicated adapters—just choose the version that matches your setup and you’re good to go. Simple, efficient, and tailored to your detailing gear.
Foam party alert
Thick and clingy foam
What really sets this foam lance apart is the impressively thick foam it produces. By precisely mixing air, water and shampoo, it creates a creamy lather that clings to your vehicle’s surface. This helps to effectively loosen dirt and grime before you even touch the paint with a wash mitt. A proper pre-wash starts with a rich foam layer, and that’s exactly what the Monello Lancia delivers. It’s not just more effective—it also makes washing your car way more fun.
Tough and clever
Durable 1L bottle with measurements
The included 1-liter HDPE bottle is not only tough, but also cleverly designed. With a clear measurement scale on the side, it allows you to easily and accurately mix the right shampoo-to-water ratio. This helps avoid waste and ensures optimal foam every time. Made from high-quality HDPE material, the bottle is built to withstand strong chemicals and frequent use. Whether you're working with heavy-duty foams or gentle shampoos, this bottle is ready for the job.
