Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
| Product number | MPCN |
| Aansluiting | Nilfisk |
| Product type | Spuitpistool |
- Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
- Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
- Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
Fijne upgrade van de ervaring
Lang getwijfeld, uiteindelijk besteld en wat ben ik blij dat ik dit heb gedaan! De hele ervaring van je auto wassen wordt een stuk beter. Ook kan ik nu veel makkelijker de foam cannon gebruiken en even wisselen tussen opzetstukken.
Super vervanger van origineel product
Na lang twijfelen besteld. In 1 woord super. Deze ligt veel fijner in de hand dan de originele Nilfisk. Ook minder vermoeiend met inknijpen.
Had ik veel eerder moeten doen!
Deze Monello Pistola Corta is echt een must have!
Bouwkwaliteit is echt top. Je merkt tijdens het uitpakken dat ieder component zorgvuldig is ontworpen en gemaakt. Fijn dat er in de tijd van wegwerp cultuur ook nog goede producten bestaan.
Ook in gebruik is deze vele malen prettiger dan de standaard lans van Nilfisk. Omdat hij zo klein is kun je een stuk makkelijker in de wielkasten en tussen de velgspaken komen.
Het enige nadeel vond ik persoonlijk de losse nozzles. Het werkt niet ideaal om deze steeds in een broek of jaszak te doen. Hier heb ik zelf een houdertje voor gemaakt.
Deze short trigger gun mag niet missen in je detailing kit!
