Pistola Corta - Kärcher
Art. nr. MPCK
5.0 (64)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
Product number MPCK
Product type Spuitpistool
  • Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
  • Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
  • Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
Ja, er zijn zowel lange als korte verlengstukken beschikbaar.
De opzetstukjes hebben verschillende graden, waarmee je de kracht van de waterstraal bepaalt:
  1. 15° (rood) – sterk, voor hardnekkig vuil
  2. 25° (groen) – medium kracht, voor carrosserie
  3. 40° (wit) – mild, voor gevoelige oppervlakken
  4. 65° (zwart) – lage druk, lijkt op een tuinslang
Dat is de Nilfisk-aansluiting.
Bij het product vind je plaatjes waarmee je kunt zien of hij op jouw hogedrukreiniger past. Bij twijfel kun je contact opnemen. Let op: hij past niet op de Parkside.
Heel wendbaar en ideaal voor kleine of laagliggende delen zoals wielkasten en velgen. Geen lompe lange spuitstukken en je kunt de spraykopjes snel verwisselen dankzij de quick release.
Ja, als je de blauwe behuizing hebt. Hiermee kun je bijvoorbeeld wisselen van Kärcher naar Nilfisk.
Mooi upgrade voor mijn Karcher K7, jammer dat je de druk niet meer aan kan passen. Als deze functie er ook op.zat was hij perfect. Misschien kan dit in de toekomst wel met de nieuwe versie.
Tijdens het wassen van je auto is dit een genot. Die zware pistool van Karcher hoef je niet te gebruiken. De Pistola Corta is heel ligt en makkelijk in gebruik. De verschillende nozzle's zijn ook heel fijn.
Twijfel je voor een upgrade? Niet doen, je zal zeker geen spijt krijgen.
Koray - 6 June 2026
Wat een verademing deze verkorte hogedrukpistool van monello
Wat werkt dit heerlijk in plaats van die lange lans van Kärcher. Je komt overal perfect bij, en de verschillende opzetstukken zijn goed voor verschillende delen van de auto zoals de velgen en de wielkasten waar je een harde straal kan gebruiken. Het verloopje voor de Kärcherslamg zit goed vast en lekt niet. Prachtig spul dat monello. Echt voor de deugnietjes
Sander - 8 April 2026
Geweldig
Heb de Foamkit aangeschaft voor mijn bosch aquatak, past perfect en werkt geweldig. Foam ziet er perfect uit, werkt top en met de diverse sproeikopjes op het pistool is er voor iedere bewerking de perfecte match te vinden.
Voelt ook heel degelijk aan, erg blij met de aankoop.
Hans - 22 March 2026
