Pistola Corta - Kärcher
Art. nr. MPCK
5.0 (64)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
Product number MPCK
Product type Spuitpistool
  • Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
  • Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
  • Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
Ja, er zijn zowel lange als korte verlengstukken beschikbaar.
De opzetstukjes hebben verschillende graden, waarmee je de kracht van de waterstraal bepaalt:
  1. 15° (rood) – sterk, voor hardnekkig vuil
  2. 25° (groen) – medium kracht, voor carrosserie
  3. 40° (wit) – mild, voor gevoelige oppervlakken
  4. 65° (zwart) – lage druk, lijkt op een tuinslang
Dat is de Nilfisk-aansluiting.
Bij het product vind je plaatjes waarmee je kunt zien of hij op jouw hogedrukreiniger past. Bij twijfel kun je contact opnemen. Let op: hij past niet op de Parkside.
Heel wendbaar en ideaal voor kleine of laagliggende delen zoals wielkasten en velgen. Geen lompe lange spuitstukken en je kunt de spraykopjes snel verwisselen dankzij de quick release.
Ja, als je de blauwe behuizing hebt. Hiermee kun je bijvoorbeeld wisselen van Kärcher naar Nilfisk.
Eerder moeten kopen
Wat een fijn pistool. Veel makkelijker om de wielkasten uit te spuiten enzo. Blij mee. Wissel van nozzle werlt eenvoudig. Wel wat zware bediening. Langere tijd inknijpen kost kracht. En je kunt er de foamlans niet op aan sluiten. Dus je moet wel af en toe wisselen.
Arjan - 9 May 2025
Helemaal top!
Veel fijner dan het standaard Karcher spuitpistool, handzaam en daardoor makkelijker te richten en opzetstukjes snel te wisselen.
Phil - 30 April 2025
Had dit eerder moeten kopen
de pistola corta al enkele keren gebruikt en resultaat is dat de lange lans van karcher in de hoek staat.
Heb een tijdje getwijfeld om deze aan te schaffen maar met wat ik nu ervaar had ik het al veel langer moeten aanschaffen.
Claude - 24 April 2025
