Quick Release Extension Bar - Long
Art. nr. MEBL0101
4.6 (9)
  • Reach all the tricky spots.
More reach.
Get to every spot
With the Quick Release Extension Bar, you can tackle even the trickiest areas with ease. Think deep wheel arches, engine bays, or the underside of your car — no more twisting or awkward positions.
The long version gives you extra control and extended reach, while the short version provides added stability for powerful spraying. Perfect for combining precision and convenience.
Comfort & control.
Solid in your hand
The rubber handle provides a comfortable grip, even under pressure. This way, you can hold the Pistola Corta firmly and spray with greater control.
Especially during extended use, you’ll notice the difference — less fatigue, more precision. The short version also allows two-handed operation, giving extra stability when spraying your car or motorcycle.
Quick switching.
Click and go
No hassle with screws or twisting. Thanks to the quick release connection, you can swap between different spray tips or accessories in seconds.
Perfect when you want to quickly switch between, for example, the foam lance and a targeted spray during cleaning. And with the storage spots in the handle, your tips are always within reach — as long as you press them in properly, of course.
Extension for spray guns with a quick release connection, such as the Pistola Corta. Made from high-quality metals for a strong, durable construction. The Quick Release Extension Bar features a comfortable rubber handle, giving you more control during cleaning, even at high pressure.
The handle also allows you to store your spray tips, keeping them always within reach. These tips are easy to swap thanks to the quick release connection, letting you switch rapidly between different attachments. The extension bar is compatible with the spray tips supplied with the Pistola Corta or with a foam lance with Quick Release type 3.
Short version
The short version (17.5 cm) is ideal for users who find the Pistola Corta a bit too powerful when used with one hand. By holding the extension with your other hand, you gain extra stability and control while spraying. Perfect for precision work and smaller vehicles.
Long version
The long version (53.5 cm) provides extra reach for hard-to-access areas, such as deep inside wheel arches, engine bays, or under the car. It’s also great for cleaning larger surfaces like campers, caravans, or patio tiles. With this extra length, you can work more comfortably and avoid bending or stretching as much.
Product number MEBL0101
Aansluiting 1/4" Quick Release
Product type Verleng- en opzetstukken
Suitable for Hoge voertuigen
Nee, spraytips worden niet meegeleverd. Je kunt de tips gebruiken die bij de Pistola Corta of een foamlans met Quick Release type 3 zitten.
De korte variant (17,5 cm) geeft extra stabiliteit en is ideaal als je de Pistola Corta met één hand te krachtig vindt. De lange variant (53,5 cm) geeft extra bereik voor lastig te bereiken plekken zoals wielkasten, motorruimte, caravans of terrassen.
Ja, de handgreep heeft plek om spraytips tijdelijk op te bergen. Zorg er wel voor dat de tips goed vastzitten, zodat ze tijdens gebruik niet losraken.
Het verlengstuk is ontworpen voor spuitpistolen met een Quick Release aansluiting, zoals de Pistola Corta. Controleer of je pistool dit type aansluiting heeft voordat je bestelt.
Korte versie voegt niet veel toe
Heb de korte versie besteld en in gebruik genomen. De extra lengte is gering en de opzetstukken blijven niet heel goed in het rubber klemmen. Al met al dus niet echt een toevoeging, twijfel nog of de lange dat wel is
Sander - 5 October 2024
Erg fijn, maar.........
Laat ik positief beginnen.
Ik heb de lange versie besteld en in de basis is het een zeer solide en prettige lans.
Echter, en nu kom ik bij mijn negatieve stukje , de rubber handgreep ligt prettig in de hand en je kan er mooi je spraytips in opbergen , maar deze zitten echt niet goed vast.
Resultaat was dat er in mijn geval tijdens gebruik een spraytip uit de houder viel en op mijn dak terecht kwam met forse lakschade tot gevolg ( stukje van ongeveer 3 bij 4mm uit de lak gesprongen. ).
Bij mij komen de spraytips er tijdens gebruik echt niet meer in.
Pascal - 20 July 2024
comfortabel
net even makkelijker in de wielkuipen schoon te maken
P - 29 June 2024
