Poorboy's World Super Slick & Suds - Rich foaming shampoo for a safe wash.
Poorboy’s World Super Slick & Suds is a highly concentrated, pH-neutral car wash soap designed to safely and effectively clean the vehicle. The formula effortlessly removes road grime and dirt without stripping existing wax layers or sealants.
During the wash, the product creates a rich, thick lather with extreme lubricity, allowing a wash mitt to glide smoothly over the paintwork and significantly reducing the risk of wash-induced scratches. After washing, the shampoo rinses off very easily without leaving any soapy residue behind, ensuring a spot-free and easy-to-dry finish.
| Product number | PB-SS32 |
| Additives | Geen toevoegingen |
| Cleaning power | Mild |
| Concentration | High (very economical) |
| Gloss Level of Surface | Glossy, Matte, Satin Finish |
| Residue-free | Yes |
Add approximately 30 ml of shampoo to a wash bucket containing 10 to 15 liters of water and agitate to create suds. Wash the vehicle from top to bottom using a high-quality wash mitt. Rinse away the foam and loosened dirt thoroughly with a gentle stream of water. Dry the surface immediately afterward with a clean, soft drying towel to prevent water spots.
Tips
Always use the two-bucket method (one bucket with shampoo and one with rinse water) to safely remove dirt and prevent swirl marks.
Preferably wash the vehicle in the shade and on a cool surface for the best, streak-free results.
Super spul! Lekker zuinig in gebruik, zelfs als je - zoals ik - met een 20 liter emmer wast.
De eerste shampoo die ik gebruik naast Meg's Gold Class. Werkt verbluffend goed en zuiniger dan de Meg's. Lost meer vuil op dan verwacht en ruikt zo ontzettend lekker dat ik zin krijg om het spul op te drinken! Droogt ook niet zo snel op als de Meg's.
Beste shampoo dat ik heb gehad, gebruikte hiervoor de meguiars NXT maar tot als ik deze probeerde.. Het vuil ging er vanzelf af zonder veel druk! De washandschoen gleed over de lak, een TOP shampoo. Ik had hem meteen met de gallon besteld en zeker geen spijt van.
