Poorboy's World Super Slick & Suds - Rich foaming shampoo for a safe wash.
Poorboy’s World Super Slick & Suds is a highly concentrated, pH-neutral car wash soap designed to safely and effectively clean the vehicle. The formula effortlessly removes road grime and dirt without stripping existing wax layers or sealants.
During the wash, the product creates a rich, thick lather with extreme lubricity, allowing a wash mitt to glide smoothly over the paintwork and significantly reducing the risk of wash-induced scratches. After washing, the shampoo rinses off very easily without leaving any soapy residue behind, ensuring a spot-free and easy-to-dry finish.
Product number PB-SS32
Additives Geen toevoegingen
Cleaning power Mild
Concentration High (very economical)
Gloss Level of Surface Glossy, Matte, Satin Finish
Residue-free Yes
Volume Large (751ml - 2L)
pH value Neutral (pH 6 - 8)
Add approximately 30 ml of shampoo to a wash bucket containing 10 to 15 liters of water and agitate to create suds. Wash the vehicle from top to bottom using a high-quality wash mitt. Rinse away the foam and loosened dirt thoroughly with a gentle stream of water. Dry the surface immediately afterward with a clean, soft drying towel to prevent water spots.
Tips
  1. Always use the two-bucket method (one bucket with shampoo and one with rinse water) to safely remove dirt and prevent swirl marks.
  2. Preferably wash the vehicle in the shade and on a cool surface for the best, streak-free results.
Poorboy's World
Old Charlotte Rd 930
H315: Causes skin irritation.
Economisch verzorgende autoshampoo
Opnieuw deze prettige autoshampoo besteld. Tip; bestel het maatbekertje mee van Carclean en gebruik voor een normaal bevuilde auto niet meer dan 20 ml op een volle emmer water. Met een extreem vieze auto werkt 40 ml heel goed. Glijdt goed over de lak, prettige geur en schuim en laat ook de waslaag redelijk netjes (hierom dus slechts 20 maar beter nog 15 ml gebruiken als de auto normaal bevuild is). Een van de populairste shampoos op Carclean, en terecht wat mij betreft. Voorheen Meguiars en Monello gehad maar deze doet er zeker niet voor onder.
Rutger - 3 May 2024
Prima product. Dop is snel kapot
Prima product. Doet zijn werk en ruikt oke. Dop is wel na 1 keer gebruik defect. Gelukkig had ik nog een oude fles van een ander merk.
Michel - 13 April 2024
Er is niet beter voor auto, boot of caravan
Gebruik dit al jaren en ook aanbevolen bij anderen die even enthousiast waren over dit product.
A.P.Grootenboer - 7 April 2024
Pure Shampoo - 750ml
€ 16.99
Q²M Bathe - 1000ml
  • Pure, daily shampoo
  • pH-neutral
  • Contains no added oils, polymers, or waxes
  • Safe for wax, sealant, and coating
€ 27.99
Kenotek
Brilliant Wash - 1000ml
  • Kwalitatieve diep-glans shampoo
  • Waterafstotend, met waxeffect
  • Pompelmoesparfum
€ 12.49
