Först Citrus Pre-Cleaner-1000ml
- Cleaner with natural oils
- Perfect for tough cleaning jobs
- Pleasant fragrance
- Economical to use
The first choice for tough cleaning jobs
When your car is really dirty, or it's time for spring cleaning, Först, a citrus Traffic Film Remover (TFR), makes the task easy.
Formulated with natural orange oil, it not only boosts cleaning power but also smells amazing!
Apply undiluted to areas that need extra attention, let the product sit for a moment to work its magic, and then rinse thoroughly with water.
Först Citrus Pre-Cleaner has more cleaning power than Snö Snow Foam because it doesn't have added air, has a higher pH, and works at full strength. The downside is that your wax and sealant may not tolerate it as well.
It's often unnecessary and wasteful to spray the entire car with Först Citrus Pre-Cleaner. Use it only on the areas that really need it, usually the lower parts of the car, like bumpers and sills. Först Citrus Pre-Cleaner is also perfect for cleaning door jambs or under the hood.
| Product number: | STFO10S |
- Spray Först Citrus Pre-Cleaner evenly on the areas you want to treat.
- Allow the product to work for 2-5 minutes, then rinse it off with water, preferably using a pressure washer.
- Do not let it dry.
Log in
3 - 3 of 18 reviews
Zeer goede werking
Dit product werkt echt goed. Bij een witte auto in de wasbox echt handig wanneer je de auto enkel wil afspuiten. Echt afspuiten en dan de delen met veel vervuiling inspuiten. Paar minuten wachten en dan weer afspuiten.........wat een verschil.
Goed schoonmaakmiddel met lekkere geur
Doet precies waar het voor bedoeld is. Daarnaast met een aangename geur. Zeer positief verrast door dit product
Doet goed zijn werk
Doet gewoon goed zijn werk Onderste gedeelte in spuiten eve wachten afspoelen en beginnen met contact was
