Master series P80 160 bar hogedrukreiniger - L-pack
Art. nr. 10-100-238
The Master series of pressure washers is the cream of the crop of pressure washers from AVA of Norway, suitable for all the jobs you can think of for a pressure washer.
The heart of the AVA Master is a durable 4-cylinder aluminum pump. The machines come with a convenient storage compartment for the attachments and power cord. The pressure washers in the Master series are extremely stable thanks to an extendable front support, a low center of gravity and the "follow me" hose reel.
The hose reel has a unique "follow me" feature and can rotate 45° horizontally to either side. This makes unrolling the hose easier and the risk, that the pressure washer will fall over when unrolling at an angle, is much smaller.
The Master comes standard with the 'Zero Force' spray gun. The spray gun is very light to operate, hence the name 'Zero Force'. This puts less strain on the hands and wrist and it can be operated with just two fingers. The AVA Master is equipped with a telescopic handle, so you can easily move the device. This is adjustable in height in different positions.
The AVA Master has another special feature that is very handy in everyday use, namely an integrated, pull-out anti-tilt device, which makes it difficult for the device to tip over when the water hose is unrolled.
* Please note that this extra powerful pressure washer requires a C-class circuit breaker in your distribution board. Please check before purchasing if you have a B or C class circuit breaker.
Available models:
P60 -145 bar
L-pack
  • 500L p/h
  • 2100W
  • 8m hose
  • 21.9 kg
P80 - 160 bar
L-Pack
  • 600L p/h
  • 2800W
  • 10m hose
  • 23.4 kg
Watch  video on how to prepare the Master for use.
This product is excluded from discount codes and other promotions.
Product number: 10-100-238
Inhoud L-pack:
  • Zero Force' spray gun
  • Steel reinforced hose 8 meters
  • Extendable zoom lance
  • Vario nozzle (20 ° / 60 °)
  • Turbo rotary nozzle
  • PN31 foam lance
  • Metal water filter
  • Multilingual manual, including Dutch
AVA of Norway AS
Nøstetorget 5
5011 Bergen, Noorwegen
AVA of Norway GmbH
Maria-Goeppert-Straße 3
23562 Lübeck, Duitsland
Powerful, professional and well‑built pressure washers that beat comparable yellow-brand models. Easy to assemble, lightweight to handle, with strong performance, quality accessories, long cables/hoses and excellent service — a great, reliable upgrade for car and home use.
1 - 3 of 20 reviews
Ava
Top kwaliteit. Eerste indruk is dat de kwaliteit echt wel een stuk beter is dan de bekende gele HD machines. Ben benieuwd hoeveel tijd we besparen bij het wassen van beide autos
Gk - 21/02/2024
Ava master serie p60 zeer fijne goed werkende hogedrukreiniger
De ava master serie p60 werkt heerlijk Auto wassen tegels schoonspuiten muren schoonspuiten Met de dakgoot en rioolkit maak je die ook mooie schoon Deze veel eerder moeten kopen kom van een nilfisk compact serie 120 bar had ik voor deze
Jurrian - 19/06/2023
Fijn apparaat
Had hiervoor een Kärcher. Maar dit is zoveel fijner Hele soepele slang. En een kort spuitpistool wat lekker werkt. Had wel een lek in het spuitpistool na een jaar gebruikt maar is Opgelost door carclean door een vervangend onderdeel. Top service weer!
Bas - 10/05/2023
Favorite
Artico Magico Snow Foam
  • Safely loosens dirt
  • Creates nice thick foam layer
  • Safe for waxes, sealants and coatings
€ 16,-
AVA
90° underbody lans voor AVA hogedrukreinigers
  • 90°-lans om lastig bereikbare plekken te reinigen
  • Ideaal voor wielkasten, motorruimte en chassis
  • Geschikt voor alle AVA hogedrukreinigers
€ 49.99
AVA
EHBO-kit voor AVA hogedrukreinigers
  • EHBO-kit voor AVA hogedrukreinigers
  • Mesh filters voor AVA foamlans
  • Diverse O-ringen
  • Dopjes voor bajonetaansluiting
€ 9.99
AVA
Microfiber Brush voor AVA hogedrukreinigers
  • Microvezel hulpstuk voor AVA
  • Uitwasbare hoes
  • Ideaal voor grote oppervlakken
  • Ideaal voor bijv. caravan, boot, garagedeur
€ 29.99
Nearly sold out
AVA
Nozzle Kit 5-delig voor AVA P30-P60
  • Set met extra nozzles voor de AVA P30 tot P60 hogedrukreiniger
  • Duidelijke kleurcodering
  • Inclusief 35cm vaste lans
€ 49.99
AVA
Terrasreiniger
  • Te gebruiken op bijna alle verharde oppervlakken
  • Ook verticaal te gebruiken
  • Te gebruiken op alle hogedrukreinigers van 120-170 bar
€ 69.99
AVA
Verlengslang staalversterkt
  • Verlengslang voor AVA hogedrukreinigers
  • Met staal versterkt
  • Vergroot de actieradius
  • Verkrijgbaar in 12 en 20 meter
€ 99.99
AVA
Telescooplans - 4 meter
  • Uitschuifbaar tot 4 meter
  • Compatibel met o.a. Kärcher, Nilfisk en Stihl
  • Eenvoudig te vervangen sproeikop
  • Beschikt over 'Zero Force' spuitpistool
€ 134,-
Nearly sold out
Offer
AVA
AVA Tuinmeubelborstel
  • AVA Tuinmeubelborstel
  • Binnen een handomdraai al je buitenmeubels schoon
  • Voor alle hogedrukreinigers van 110-160 bar
Retail price: € 24.99 € 19.99
AVA
AVA Gevelborstel
  • AVA Gevelborstel
  • Ideaal voor het reinigen van o.a. tuinmuren, garagedeuren en meer!
  • Geschikt voor alle hogedrukreinigers van 110-160 bar
€ 39.99
Nearly sold out
AVA
Zelfaanzuigende slang voor AVA - 3 meter
  • Uses water from various sources other than the tap connection
  • Easily pumps water from a pool, pond or fountain
  • Includes water filter that helps prevent damage
€ 49.99
Nearly sold out
AVA
Wandrek voor AVA-accessoires
  • Arranges all your AVA accessories quickly and easily
  • Quickly mounts to any wall
  • Made of sturdy aluminum
€ 45.99
Nearly sold out
