Detail Wheel Brush Mini
Art. nr. EZ-Mini
4.4 (105)
EZ Detail Mini Brush - The specialist for tight spaces
The EZ Detail Mini Brush is a more compact version of the well-known large EZ Detail brush, specifically designed for cleaning areas with limited space. This brush is perfectly suited for wheels with many spokes, complex patterns, engine bays, exhaust tips, and grilles. Thanks to the flexible stem, the brush can be bent into various angles to reach the back of spokes or brake calipers.
The bristles are made of soft Nylex nylon, ensuring safe cleaning without scratching paint or chrome finishes. The bristles are resistant to harsh chemicals and do not permanently deform; heat helps them return to their original state. Both the tip of the brush and the handle feature rubber guards to prevent accidental damage during use.
Product number EZ-Mini
Additional features Buigbaar
Made from material Nylon/Memory-Nylex
Size Small
    1. Mix a wheel cleaner or car shampoo with water in a bucket.
    2. Immerse the brush in the soapy water to ensure proper lubrication.
    3. Gently move the brush between spokes and into wheel barrels.
    4. Rinse the brush frequently in the bucket to release trapped dirt.
    5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
    6. Hang the brush to dry; the bristles will regain their original shape.
    Tips
    • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
    • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Goede wheelbrush
Fijne handzame wheel brush, niet te harde en stijve haren zoals goedkopere alternatieven waardoor deze brush minder spettert. Ligt goed in de hand en makkelijk te gebruiken door de velgen heen.
Piet - 29 September 2026
Wheel Brush
Zeer handige velgen borstel. Alleen is hij naar mijn inzicht iets te zacht. Spettervrij is hij zeer zekers niet. Maar voldoet aan de eisen die er aan gesteld worden.
Rémon - 8 July 2026
kan niet tippen aan de ez borstel
deze gekocht maar deze is gewoon een stuk minder van kwaliteit dan de ez, haren komen niet mooi terug in vorm in warm water, haren zijn ook een stuk slappen, dopje op de punt was al snel verdwenen waardoor er nu dus gewoon blank staal uitsteekt, ik ga weer op zoek naar een ez detail.
B.A. - 21 June 2026
Antwort des Online-Shops: We denken toch dat je een pechgevalletje had, deze borstel is lang en uitvoerig getest en komt eigenlijk op elk vlak beter uit de test. De Amerikaanse versie moesten wij juist om de haverklap repareren, omdat de dopjes loskwamen. Het was op een gegeven moment zo erg, dat we standaard losse dopjes meegeleverd kregen. Ook brak de Amerikaanse versie veel vaker dan deze nieuwe versie. En van de haren verbaast ons wel, ook dat hebben we lang getest en eigenlijk hebben we geen verschil gevonden. Zou jij jou borstel aan ons willen retourneren? Dan kunnen we testen en vergelijken. Dankjewel!
