Exterior
Water just rolls off
Durable Water-Repellent Coating
Gyeon Q² FabricCoat provides long-lasting protection for all types of textile surfaces. Thanks to its advanced formula, it creates an invisible layer that repels water and prevents moisture from penetrating the fibers. This ensures that fabrics like car upholstery, carpets, and fabric-covered surfaces stay dry and clean, even in heavy rain. The strong adhesion to textiles guarantees long-term effectiveness, reducing the need for frequent reapplication. With Gyeon Q² FabricCoat, your interior stays fresh and free from water damage.
No chance for mud and spills
Invisible Barrier Against Dirt
In addition to being water-repellent, Gyeon Q² FabricCoat also acts as an effective shield against dirt and stains. Thanks to its innovative SiO₂ technology, it prevents liquids, mud, and dust from penetrating deep into the fabric. Spilled drinks or splattered dirt have no chance of leaving stubborn stains, keeping your upholstery cleaner for longer. This makes it ideal for everyday use in cars, on furniture, and even on outdoor fabrics. Cleaning becomes much easier since dirt struggles to cling to the surface.
Drop the top (but stay dry)
Perfect for Convertible Tops
Convertible tops are constantly exposed to changing weather conditions, from scorching sun to heavy rain. Gyeon Q² FabricCoat creates a strong protective layer that makes the roof water-repellent and prevents dirt and algae buildup. This keeps the fabric in top condition and reduces the risk of mold growth and discoloration. Thanks to its long-lasting effect, you can worry less about maintaining your convertible. Rain effortlessly beads up and rolls off, allowing you to enjoy a clean and well-protected roof for longer.
Gyeon Q² FabricCoat is a durable water-repellent coating for textiles. Not only does it protect the surface, but it also impregnates the fibers, creating a long-lasting barrier against water and dirt. The UV protection helps prevent color fading. The formula contains only the highest quality ingredients to stand out in durability compared to other similar products. Suitable for upholstery, mats, carpets, and convertible tops.
Consumption is approximately 80ml of product per 1m².
| Product number | GYFAB01 |
| Additives | Ceramic (SiO²) |
| Durability | 6-12 months |
| Especially for | Fabric convertible roofs |
| Suitable for material | Textile |
| Volume | Small (0 - 400ml) |
- Reinigen: Zorg voor een volledig schoon en droog oppervlak.
- Aanbrengen: Spray gelijkmatig op het textiel (verbruik: ca. 80ml/m2.
- Inwerken: Wrijf het product licht in met een zachte borstel of een handschoen voor maximale vezelbinding.
- Drogen: Laat het oppervlak minimaal 12 uur rusten in een droge omgeving. Vermijd contact met water tijdens het uitharden.
Let op: Altijd gebruiken in een goed geventileerde ruimte. Dek omliggende plastic- of lakdelen af om overspray te voorkomen.
Top product
Na het bekijken van de video over het reinigen van een cabriodak , onmiddellijk gekocht . En ik moet zeggen , het doet zijn werk prima . Het water loopt eraf .
Super goed voor alcantara
Met 4 spuitjes op een gyeon applicator inwrijven op de bekleding, met je handschoen verder inwrijven. Nachtje laten drogen en de volgende dag nog een laagje , bekleding is als nieuw!
Top spul!!
Super spul
Gemakkelijk aan de brengen.
Eerst cabrio dak goed schoonmaken en laten drogen.
Cabrio dak ligt inspuiten en met rubberen handschoen in wrijven
En druppels water rollen er nu zo af.
