Q²M CeramicDetailer - 1000 ml
Art. nr. GY-CD-1000
4.8 (29)
  • The Perfect Boost for Your Paint
    Q²M CeramicDetailer
Ceramic maintenance made easy
Preserve the ultimate protection
The Gyeon Q²M CeramicDetailer is specifically designed for maintaining ceramic-coated vehicles. Thanks to its SiO₂-enriched formula, this detailer helps extend the protection and hydrophobic properties of the coating. As a result, the paint stays cleaner for longer and retains its deep gloss. The product adds extra slickness and enhances water beading, making it harder for dirt and water to adhere. This keeps your coating in top condition without needing to apply a new protective layer constantly.
Spray, wipe, and done
Super easy to use
With Gyeon Q²M CeramicDetailer, you save time and effort. The formula is incredibly easy to work with: simply spray it onto the paint and wipe it off with a microfiber cloth for a streak-free finish. It also works great as a drying aid, as it has water-repellent properties that help remove water droplets from the surface quickly. This prevents water spots and speeds up the drying process. Whether you want a quick refresh or an effortless drying solution after washing, this detailer gets the job done.
Suitable for every car, no discrimination
Universal perfection
Whether your car has a classic solid paint, a modern metallic finish, or a deep pearl effect, Gyeon Q²M CeramicDetailer is ready for it. The product is safe to use on all paint types, coated or uncoated, and always delivers a smooth and glossy finish. Even if your car isn’t ceramic-coated, you’ll still benefit from its hydrophobic and dirt-repelling properties. This way, every car enjoys a professional look without the hassle of complicated application processes.
Gyeon Q²M CeramicDetailer is the perfect maintenance product for ceramic-coated surfaces, combining the best of both worlds: spray sealants and traditional quick detailers. This is exactly where the name CeramicDetailer comes from!
Q²M CeramicDetailer is just as easy to use as the well-known Q²M QuickDetailer. It can be applied to both dry and wet paint, and when used on wet surfaces, it also serves as a handy drying aid. Q²M CeramicDetailer is suitable for all types of paint, including coated surfaces.
Product number GY-CD-1000
Additional features Water Repellent
Additives Ceramic (SiO²), Gloss enhancers
Concentration Ready to Use
Suitable for application Drying help, Removing Bird Droppings
To be applied wet Yes
Volume Large (751ml - 2L)
  1. Spray a generous amount of product onto a damp microfiber cloth.
  2. Wipe the product over the surface.
  3. Perfect the finish with a dry Q²M SoftWipe.
Bukit Batok Crescent 1
04-25 Singapore, Singapore
Zeer goed produkt
Heel makkelijk aan te brengen. Geeft een diep, glanzend effect.
Steve - 12 March 2026
Perfectie
Deze detailer werkt fijn op mijn grijze auto en strepen zijn makkelijk weg te wrijven. Druppels parelen zo van mijn auto af.
M. - 17 October 2025
lelijke waas na gebruik
Product is niet te doen. Iedere keer als je dit gebruikt krijg je hele lelijke strepen die je niet weg krijgt met het uitwrijven met een schone droge microvezeldoek. Gebruikte het op een gyeon certified infinite coat.
Zodra je dauw ziet zie je precies waar je het product gebruikt hebt.
R - 23 August 2025
Offer
Sonax
Xtreme Ceramic Ultra Slick Detailer - 750ml
  • Snelle detailer met parelend effect
  • Geschikt om lichte vervuiling te verwijderen
  • Frist bestaande coatings op
  • Boost glans
Retail price: € 16.99 € 13.49
Collinite
Slickr 3 in 1 Ceramic Detailer - 473ml
  • Multiple use detailer
  • Super-hydrophobic effect
  • Boost gloss
  • Use as drying aid
€ 17.99
Offer
Turtle Wax
Hybrid Solutions Ceramic 3-in-1 Detailer - 500 ml
  • Gemakkelijke detailer
  • Te gebruiken tussen de wasbeurten door
  • Houdt het voertuig langer schoon
Retail price: € 26.99 € 18.99
Nearly sold out
Offer
Meguiars
Hybrid Ceramic Detailer - 768ml
  • Perfect voor tussen de was- en waxbeurten door
  • Voor het verwijderen van lichte vervuiling en stof
  • SiO2-keramische bescherming zorgt voor extreme waterbeading
Retail price: € 30.56 € 24.45
