Ceramic maintenance made easy
Preserve the ultimate protection
The Gyeon Q²M CeramicDetailer is specifically designed for maintaining ceramic-coated vehicles. Thanks to its SiO₂-enriched formula, this detailer helps extend the protection and hydrophobic properties of the coating. As a result, the paint stays cleaner for longer and retains its deep gloss. The product adds extra slickness and enhances water beading, making it harder for dirt and water to adhere. This keeps your coating in top condition without needing to apply a new protective layer constantly.
Spray, wipe, and done
Super easy to use
With Gyeon Q²M CeramicDetailer, you save time and effort. The formula is incredibly easy to work with: simply spray it onto the paint and wipe it off with a microfiber cloth for a streak-free finish. It also works great as a drying aid, as it has water-repellent properties that help remove water droplets from the surface quickly. This prevents water spots and speeds up the drying process. Whether you want a quick refresh or an effortless drying solution after washing, this detailer gets the job done.
Suitable for every car, no discrimination
Universal perfection
Whether your car has a classic solid paint, a modern metallic finish, or a deep pearl effect, Gyeon Q²M CeramicDetailer is ready for it. The product is safe to use on all paint types, coated or uncoated, and always delivers a smooth and glossy finish. Even if your car isn’t ceramic-coated, you’ll still benefit from its hydrophobic and dirt-repelling properties. This way, every car enjoys a professional look without the hassle of complicated application processes.
Gyeon Q²M CeramicDetailer is the perfect maintenance product for ceramic-coated surfaces, combining the best of both worlds: spray sealants and traditional quick detailers. This is exactly where the name CeramicDetailer comes from!
Q²M CeramicDetailer is just as easy to use as the well-known Q²M QuickDetailer. It can be applied to both dry and wet paint, and when used on wet surfaces, it also serves as a handy drying aid. Q²M CeramicDetailer is suitable for all types of paint, including coated surfaces.
| Product number | GY-CD-1000 |
| Additional features | Water Repellent |
| Additives | Ceramic (SiO²), Gloss enhancers |
| Suitable for application | Drying help, Removing Bird Droppings |
| To be applied wet | Yes |
- Spray a generous amount of product onto a damp microfiber cloth.
- Wipe the product over the surface.
- Perfect the finish with a dry Q²M SoftWipe.
Verslavend om meer te gebruiken!
Geeft een mooie diepe glans! Makkelijk in gebruik. Geen opdroogde waterdruppels of waas i.c.m. een droogdoek. En verbergt hier en daar ook nog wat kleine krassen. Het is letterlijk een 3 in 1 product.
Prachtig resultaat zonder moeite
Ik gebruik de Q2M detailing spray voor het drogen van de auto. Dus terwijl de auto nog nat is, een beetje spray op de lak en op de speciale droogdoek. Voorheen had ik nog wel eens watervlekken en vettige waas, maar met de Q2M detailing spray is de glans verbluffend. De "normale" spray van Q2M werkt al perfect, maar omdat mijn auto is behandeld met een keramische coating gebruik ik nu dit product.
Super glad en mooie glans
Na een tegenvallende quick detailer van Gyeon te hebben geprobeerd zocht ik een alternatief voor Cure.
Dat heb ik in de ceramic detailer zeker gevonden. Het product laat een mooie diepe glans achter en wordt na het afnemen super glad.
De beading ziet er top uit, al is het de vraag hoe goed het product zich houdt qua standtijd.
