Q²M Foam - 1000ml
Art. nr. GYFOA10
4.3 (19)
  • Foamparty
    Q²M Foam
Thick Foam Party
Powerful Pre-Wash Foam
The Gyeon Q²M Foam is a high-quality pre-wash foam that creates a thick, clingy layer of foam on your vehicle. This foam penetrates deep into the dirt and loosens it without the need for scrubbing. Thanks to its long-lasting adhesion to the surface, the cleaning agent has time to do its job, effectively removing dirt safely. This makes it the perfect first step in a thorough wash, as it helps prevent scratches and swirls during contact washing.
Fles, Machine, Wiel
Goodbye, Mud
Removes Heavy Contamination
Mud, road grime, and other heavy dirt stand no chance against Gyeon Q²M Foam. Thanks to its powerful formula, it breaks down even stubborn buildup without damaging the paint. This means you get a cleaner vehicle with minimal effort before moving on to hand washing. It prevents dirt from accumulating in your sponge or mitt, which is crucial for keeping your paint in top condition. Whether you've just returned from an off-road adventure or driven through bad weather, this foam takes care of it effortlessly.
Worry-Free Foaming
Safe for Every Surface
Gyeon Q²M Foam is not only powerful but also safe for all types of surfaces. Whether your car has a ceramic coating, is wrapped, or even features uncoated aluminum, this foam does its job without causing damage. Its pH-neutral formula ensures that delicate parts of your vehicle remain unharmed while effectively removing dirt. This makes it an ideal choice for both enthusiasts and professionals looking for a safe, reliable pre-wash without compromise.
Gyeon Q²M Foam - The Ultimate Pre-Wash Experience
A pH-neutral snow foam designed to safely and effectively loosen dirt from the surface. This product is the ideal first step in the washing process. The thick layer of foam encapsulates dirt, sand, and other contaminants, significantly reducing the risk of wash-induced scratches during the main hand wash.
The formula is completely safe for existing coatings and all surfaces. The foam clings to the surface for an extended period, allowing for maximum dwell time without drying out. After dwelling, the product can be easily rinsed away, taking a large portion of the contamination with it and leaving behind a clean surface, ready for the next step in the washing process.
Compatible with all foam lances for pressure washers and hand foamers.
Product number GYFOA10
Cleaning power Strong
Concentration Concentrate
Gloss Level of Surface Glossy, Matte, Satin Finish
Volume Large (751ml - 2L)
pH value Very alkaline (pH 13 - 14)
  • Dilute Q²M Foam 1:5 for heavy contamination and 1:15 for light contamination.
  • Foam the vehicle from bottom to top and wait 5-8 minutes before thoroughly rinsing off.
  • Do not let it dry; rinse off in time.
  • Do not use in full sunlight.
Bukit Batok Crescent 1
04-25 Singapore, Singapore
Dikke foam.
Tot nu toe tevreden over alle producten van geyon.
Eddy - 3 October 2025
Goed Product van GYEON!
Gebruik het al een tijd en blijft heerlijke foam om te gebruiken ligt aan de hoeveelheid dat je gebruikt hoe lekker dik de foam word meestal 1:10 gebruikt en doet zijn werk zoals het hoord!
Jeroen - 28 July 2025
Dikke goede foam
Beste foam, goede dikke laag, alle vuiligheid loopt er zo vanaf!
Bjorn - 29 March 2025
