Q²M Iron - 4000ml
Art. nr. GYIRO40
4.6 (73)
  • Quick, safe cleaning for paint, wheels, and glass.
    Remove iron in one go
Powerful iron removal.
Removes even stubborn dirt
Q²M Iron dissolves industrial fallout, brake dust, and rail particles quickly and effectively. Even deeply embedded contamination is visibly removed, leaving your paint, wheels, and glass looking clean and smooth.
Safe for all surfaces.
pH-neutral and coating-friendly
Use Q²M Iron worry-free on paint, glass, wheels, and trim. The pH-neutral formula is gentle on surfaces and safe for ceramic coatings.
Visible results.
Color change shows it’s working
During use, Q²M Iron turns purple as it reacts with iron particles. This way, you can see exactly where the product is working – fast, effective, and without any guesswork.
Effectively remove iron
Q²M Iron is one of the most powerful and fastest-working products for removing iron particles, industrial fallout, and brake dust. The advanced formula makes cleaning easier and delivers faster results for both enthusiasts and professionals.
Safe for paint, wheels, and glass
Use Q²M Iron on paint, wheels, trim, and glass. Thanks to its pH-neutral composition, it’s completely safe for all surfaces — even coated cars. It loosens even the most stubborn brake dust or deeply embedded grime.
During use, Q²M Iron changes color: the liquid turns purple as it reacts with iron particles, showing exactly where it’s working. The updated formula also has a milder scent, making it more pleasant to use.
Tip
Use Q²M Iron as part of your regular paint decontamination process, before claying or applying a protective layer. Always work on a cool surface and rinse thoroughly for the best results.
With Q²M Iron, you’ll remove contamination that regular washing can’t touch — for a visibly cleaner and smoother finish.
Product number GYIRO40
Acid-free Yes
Additives Iron remover
Cleaning power Strong
Colors Purple Yes
Concentration Ready to Use
Consistency Liquid
Viscosity Thin
Volume Extra large (more than 2L)
pH value Neutral (pH 6 - 8)
  1. Cool surface – Use in the shade, not on hot panels.
  2. Spray – Apply generously to paint, wheels, or glass.
  3. Wait – Let it work for 1–2 minutes. The liquid will turn purple.
  4. Optional brushing – Use a brush or cloth for stubborn dirt.
  5. Rinse – Rinse thoroughly with water. Done!
Bukit Batok Crescent 1
04-25 Singapore, Singapore
H302: Harmful if swallowed.
Acceptabel
Ach ja, het stinkt. Als het maar werkt denk ik dan. Wat dat betreft al voldoende reacties gelezen om het zelf ook eens te bestellen. Wat schets mijn verbazing: je moet het sprenkelen in plaats van sproeien. Lijkt mij wat onhandig, helemaal als je bij het bestellen gewoon een sproeikop gemonteerd ziet op de fles! Nu eerst maar eens een fles dasty versneld leeg werken en de sproeikop overzetten. Beetje jammer, hoop dat het wel zo werkt als door een ieder beschreven.
Ronald van Nus - 24 July 2014
Dit is het eerste middel wat ik het getest op vliegroest. Moet zeggen dat het super werkt! De vliegroest lost gewoon op, er hoefde geen wash mitt aan te pas te komen.
Nadeel is dat het inderdaad stinkt.
Alexander - 8 June 2014
Fantastisch
Toen ik in de keuken de dop vast van de fles draaide en toen heel even wegliep om een schaar te pakken om dat zuigslangetje op maat te kunnen maken van die spuitkop, voel ik haast achterover van de indringende geur!
Keuken een uur moeten luchten!
Maar goed, spul gebruikt en doet wat het moet doen.
Mijn toch redelijk verwaarloosde gepolijste Alu wielen glimmen weer als vanouds!
er zal best beter spul zijn, maar dit werk voor mij goed.
Martin Brons - 26 April 2014
