Earn Polishpoints with every order for extra discounts! Discover more!
Q²M Iron - 500ml
Art. nr. GYIRO05
Effectively remove iron
Q²M Iron is one of the most powerful and fastest-working products for removing iron particles, industrial fallout, and brake dust. The advanced formula makes cleaning easier and delivers faster results for both enthusiasts and professionals.
Safe for paint, wheels, and glass
Use Q²M Iron on paint, wheels, trim, and glass. Thanks to its pH-neutral composition, it’s completely safe for all surfaces — even coated cars. It loosens even the most stubborn brake dust or deeply embedded grime.
During use, Q²M Iron changes color: the liquid turns purple as it reacts with iron particles, showing exactly where it’s working. The updated formula also has a milder scent, making it more pleasant to use.
Tip
Use Q²M Iron as part of your regular paint decontamination process, before claying or applying a protective layer. Always work on a cool surface and rinse thoroughly for the best results.
With Q²M Iron, you’ll remove contamination that regular washing can’t touch — for a visibly cleaner and smoother finish.
Product number: GYIRO05
Consistency: Liquid
H302: Harmful if swallowed.
  1. Cool surface – Use in the shade, not on hot panels.
  2. Spray – Apply generously to paint, wheels, or glass.
  3. Wait – Let it work for 1–2 minutes. The liquid will turn purple.
  4. Optional brushing – Use a brush or cloth for stubborn dirt.
  5. Rinse – Rinse thoroughly with water. Done!
Powerful and reliable wheel and iron remover that restores wheels and paint to like-new condition with quick, visible results; safe on alloys and paint, economical in use — note: very strong smell, best used outdoors and with ventilation or gloves.
1 - 3 of 73 reviews
Ideaal en super effectief
Velg inspuiten, in laten trekken en daarna zonder velgenborstel afspuiten en is hele brandschoon
Jordy - 14/06/2026
Must have voor elke detailer
Ik ben zo blij met Gyeon Iron dat ik het altijd koop in 4 liter flessen, altijd als ik mijn auto's was maakt dit product mijn leven zoveel makkelijker. Het stinkt vreselijk en als de vlekken op je handen of je kleding komen zul je direct moeten douchen want die lucht blijft hangen maar daar staat wel een hele goeie reiniger tegenover. Ik gebruik misschien 100 ml voor 1 auto, en met auto's met circuit blokken moet je ook wel omdat het heel hardnekkig is maar gelukkig maar Iron daar snel korte mette mee. Ik zou het aanraden maar trek wel handschoenen aan of zorg dat je daarna lekker gaat douchen want het is wel rotzooi.
Remy - 02/06/2026
Goed spul
Zichtbaar goed werkend en veilig product.
Evertjan - 16/05/2026
  • Quick, safe cleaning for paint, wheels, and glass.
    Remove iron in one go
Powerful iron removal.
Removes even stubborn dirt
Q²M Iron dissolves industrial fallout, brake dust, and rail particles quickly and effectively. Even deeply embedded contamination is visibly removed, leaving your paint, wheels, and glass looking clean and smooth.
Safe for all surfaces.
pH-neutral and coating-friendly
Use Q²M Iron worry-free on paint, glass, wheels, and trim. The pH-neutral formula is gentle on surfaces and safe for ceramic coatings.
Visible results.
Color change shows it’s working
During use, Q²M Iron turns purple as it reacts with iron particles. This way, you can see exactly where the product is working – fast, effective, and without any guesswork.
Favorite
Non-Ferro - 500ml
  • Effective fly rust remover
  • Perfect as a wheel rim cleaner
  • pH neutral
  • Turns purple so you know it works
€ 14.99
Dodo Juice
  • pH-neutrale de-ironiser
  • Verwijdert moeiteloos vastzittend remstof
  • Perfect voor het verwijderen van vliegroest
  • Kleurt paars
€ 14.99
Koch-Chemie
Reactive Rust Remover - 500ml
  • Removes fallout and brakedust
  • Effective purple color indicator
  • pH-neutral formula
  • Safe for paintwork
  • € 19.01
    • Tast coatings niet aan
    • pH- neutrale formule
    € 16.49
