Q²M Iron WheelCleaner - 500 ml
Art. nr. GY-IWC-500
The Gyeon Q²M Iron WheelCleaner is a special and highly effective cleaner for all types of wheels and finishes. The Iron WheelCleaner is formulated with a powerful formula to efficiently remove dirt and brake dust.
The Q²M Iron WheelCleaner ensures you get the most out of your wheel washing routine. The cleaner has a gel-like consistency, allowing it to adhere excellently to the surface, loosening and dissolving dirt particles. The "IRON" in the name signifies its strong ability to remove iron deposits without losing the typical wheel-cleaning characteristics of the product. The Iron WheelCleaner is a powerful cleaner, yet safe for all types of rims and finishes, whether coated or uncoated. The formula makes it an ideal solution for cleaning and maintaining wheels without any risk of damaging the finish.
Product number: GY-IWC-500
  • Contents: 500ml, 1000ml, and 4000ml
  • Consumption: 100ml per car
  • pH neutral
  • Safe for all types of wheels and finishes
Bukit Batok Crescent 1
04-25 Singapore, Singapore
H315: Causes skin irritation.
  • Always use the Q²M Iron WheelCleaner on a cooled wheel and avoid direct sunlight
  • Spray the Iron WheelCleaner generously on the wheel and brake caliper
  • Allow it to sit for 1 to 2 minutes before rinsing the wheel thoroughly
  • For even more cleaning power, you can apply the Q²M Iron WheelCleaner with your favorite wheel brush or mitt
Powerful, reliable wheel cleaner that removes stubborn brake dust and dirt effectively, often outperforming rivals; pleasant to good coverage and economical use. Spray heads can be fragile and the scent is strong for some, but results and repeat satisfaction make it highly recommended.
12 - 3 of 34 reviews
Werkt goed, adem het niet in
Zoals beschreven.. werkt tot zover uitstekend maar wát een lucht komt er van af. Nog een tandje erger dan Monello Non-Ferro. Dus diep inademen, sprayen, naar de volgende velg en uitademen. Qua resultaat: moet wel zeggen dat ik mijn velgen nooit heel lang vuil laat. Ik ga tussen de wasbeurten in regelmatig naar de wasbox en dan gebruik ik (sinds kort) dit product. Even laten inwerken (ook op de remklauwen) en je ziet het spul goed zijn werk doen. Afspuiten en ik heb voor 90% een schone velg. Toch ff een lekker gezicht tussen de wasbeurten door.
Mitch - 14/06/2021
  • Strong, safe & effective
    Wheelcleaner, redefined
Wheels in Top Shape
Powerful Cleaning
The Gyeon Q²M Iron WheelCleaner is an advanced wheel cleaner specifically designed to effortlessly remove stubborn dirt and brake dust. Thanks to its unique formula, the cleaner effectively adheres to contaminants and breaks them down without damaging the wheel. The cleaner changes color as it works, allowing you to see exactly where it is active. This makes it an essential product for car enthusiasts who want to keep their wheels in top condition without using aggressive chemicals.
Lichtmetalen velg, Autowiel, Spaak, Band, Wiel
No Wheel Left Behind
Universal Compatibility
Whether you have polished, matte, or painted wheels, the Gyeon Q²M Iron WheelCleaner is suitable for all types of wheels and finishes. Its pH-neutral formula ensures that even delicate surfaces can be cleaned safely without the risk of discoloration or damage. This makes it a reliable choice for anyone looking to maintain their wheels professionally, regardless of the material or coating.
Brake Dust? Not a Chance
Deep Cleaning
Brake dust and stubborn road grime can settle deep into the pores of your wheels, but with Gyeon Q²M Iron WheelCleaner, this problem is easily solved. The powerful formula breaks down iron particles and lifts dirt effectively from the surface, leaving your wheels looking as good as new. This not only ensures a brilliant shine but also helps prevent corrosion and damage caused by accumulated dirt.
Favorite
Non-Ferro - 500ml
  • Effective fly rust remover
  • Perfect as a wheel rim cleaner
  • pH neutral
  • Turns purple so you know it works
€ 15,-
Koch-Chemie
Magic Wheel Cleaner - 500ml
  • Acid-free, powerful wheel cleaner
  • Effective color indicator
  • Excellent adhesion
  • Safe for wheels
  • € 19.01
    • Tast coatings niet aan
    • pH- neutrale formule
    € 16.49
    Stjärnagloss
    • Krachtige ijzerverwijderaar
    • Met extra zeeptoevoeging
    • Veilig voor gevoelige delen
    € 15,-
