Active Foam - 1000ml
Koch-Chemie Active Foam - Effective and Gentle Pre-Wash
Koch-Chemie Active Foam is a high-quality foam developed for a thorough and safe pre-wash of your vehicle. The product creates a thick, stable blanket of foam that loosens and encapsulates dirt on the paintwork. This significantly reduces the risk of scratches during the main wash.
The formula is tough on dirt but gentle on the car. Thanks to its pH-neutral value, it does not affect existing wax or sealant layers, keeping your paint's protection intact. The pleasant sandalwood scent also enhances the washing experience. Active Foam is the ideal first step for anyone who wants to clean their car effectively and without causing scratches.
| Product number | 282001 |
| Cleaning power | Normal |
| Gloss Level of Surface | Glossy, Matte, Satin Finish |
| pH value | Slightly alkaline (pH 9 - 10) |
- Depending on your foam cannon or foam sprayer, dilute the product. A common ratio is 1:10 (1 part product to 10 parts water), but adjust this to achieve your desired foam thickness.
- Spray the entire vehicle with foam, starting from the bottom and working your way up.
- Allow the foam to dwell for several minutes to act on the dirt. Do not let the product dry on the surface.
- Thoroughly rinse the vehicle with a pressure washer, working from the bottom up, to remove the loosened dirt.
- Proceed with your regular hand wash.
Do not use Active Foam in direct sunlight or on a hot surface.
Kwaliteitsfoam
Ik heb recent de active foam van Koch chemie aangeschaft en gebruikt.weekt het vuil goed los en ruikt heerlijk , ook een topproduct van Koch chemie.
Topproduct
Geeft mooie laag foam en verwijdert het vuil zoals het hoort.
Super foam
Dit is een goede fijne foam. Ik gebruik hem in een foam cannon en het geeft een mooie dikke foam op de auto. Wat mij betreft een aanrader.
