Gentle Snow Foam - 1000ml
Art. nr. 383001
4.9 (13)
Koch-Chemie Gentle Snow Foam - The gentle powerhouse for a clean car.
A pH-neutral cleaning foam with a pleasant cherry scent that can be used as a snow foam in a foam cannon or as a shampoo for a manual wash. The product develops an even and well-adhering foam blanket that effectively loosens dirt from the surface. Thanks to its mild, pH-neutral formula, it is safe for all surfaces and will not strip existing wax or sealant layers. This makes it the ideal choice for regular maintenance washes. For stubborn dirt, the cleaning power can be enhanced by adding a dash of Green Star (alkaline cleaner).
Product number 383001
Cleaning power Mild
Concentration Concentrate
Gloss Level of Surface Glossy, Matte, Satin Finish
Scent Fresh, Fruity
Volume Large (751ml - 2L)
pH value Neutral (pH 6 - 8)
  • For pre-washing (snow foam): Mix approximately 20-50 ml of Gentle Snow Foam with 950 ml of water in a foam cannon. Foam the vehicle from the bottom to the top. Allow the foam to dwell for a few minutes, but do not let it dry. Rinse thoroughly with a pressure washer.
  • For hand washing: Add approximately 50 ml of Gentle Snow Foam to 10 liters of warm water. Wash the surface from top to bottom with a soft wash mitt. Rinse the mitt frequently in a separate bucket of clean water. Rinse the entire vehicle after washing.
Tip: For an extra powerful cleaning solution, for example to remove insect residue, 10-30 ml of Koch-Chemie Green Star can be added to the snow foam mixture.
Koch-Chemie GmbH
Einsteinstraße 42
59423 Unna, Duitsland
Corrosion: Corrosive
Ruikt lekker!
Denk dat het prima schoonmaakt.
En het foamt zoals de naam al doet vermoeden goed.
Ik gebruik deze foam vooral om (naast mn emmer met sop) de auto in te foamen om zo super slippery te kunnen wassen.
Puur als pre wash foam (qua reiniging) nog niet echt te beoordelen door mij.
Maakt wel mooi dikke foam. Die goed loszittend vuil kan afvoeren (foam druipt mooi af)
Jeroen - 28 July 2025
