ProtectorWax - 1000ml
Koch-Chemie ProtectorWax - Innovative high-gloss preservation wax
Koch-Chemie ProtectorWax is an advanced wax that combines a deep, mirror-like shine with long-lasting protection. This preservation wax creates an extreme water-repellent effect, causing water and dirt to effortlessly slide off the paintwork. This 'easy to clean' effect simplifies future washes. The formula bonds to the surface, providing a noticeably smoother finish and protecting paint, plastic, and rubber parts from the elements.
Note:sprayer not included.
| Product number | 319001 |
| Additional features | Glossy |
| Concentration | Concentrate |
| Consistency | Liquid |
| Durability | Medium |
| Size | Large |
| To be applied wet | Yes |
- Ensure the vehicle is clean and wet.
- Dilute approximately 30 ml of ProtectorWax with 1 litre of water in a pump sprayer or foamer.
- Evenly spray the product over the panel which is still wet.
- Rinse off directly with a pressure washer. Apply panel by panel.
- Dry any remaining water with a drying towel for a perfect, streak-free result.
Tip
- For the best results, do not apply in direct sunlight or on hot surfaces. A cool, shaded area is ideal. Do not let the product dry on the paintwork to avoid stains.
Fijn product
Erg te spreken over ProtectorWax! In de foam cannon na het wassen aangebracht op de auto. Even laten staan en afspuiten maar. Je ziet direct het hydrofobe karakter van de wax werken. Fijne geur en goed te verwerken. Ook is het erg zuinig in gebruik.
Heerlijk spul
Goed spul, aan brengen in foam of spray ff wachten, af spuiten. En het water loopt er van af.
Doet wat het moet doen
Gebruik dit op mijn mijn auto die gewaxed is en dit verlengt de standtijd aanzienlijk mooie combinatie.
