Rapid Rinseless Wash - 5000ml
Art. nr. 475005
Koch-Chemie Rapid Rinseless Wash - Washing without water has never been easier.
The Koch-Chemie Rapid Rinseless Wash, also known as Rrr, is the ideal solution for a quick and thorough wash without the need for a garden hose or high-pressure cleaner. This versatile product is specially developed to clean the vehicle in a safe and efficient manner, encapsulating dirt for safe removal without causing scratches. In addition to its cleaning action, it leaves behind a water-repellent and gloss-enhancing finish.
The Rapid Rinseless Wash is not only suitable for a rinseless wash but can also be used as a quick detailer, a drying aid after a traditional wash, or even as a clay lubricant. The formula is gentle on all exterior surfaces, including paint, glass, plastic, and wheels.
Product number: 475005
Koch-Chemie GmbH
Einsteinstraße 42
59423 Unna, Duitsland
  1. Dilute the Rapid Rinseless Wash according to the recommended ratio (approx. 30 ml to 10 liters of water) in a bucket.
  2. Soak several microfiber towels in the solution.
  3. Take a towel and wash the vehicle panel by panel, from top to bottom.
  4. Use a clean, dry microfiber towel to immediately wipe and buff the treated panel to a high shine.
  5. Replace the wash towel with a clean, wet one as soon as it becomes saturated with dirt.
Tip: For an extra smooth and water-repellent effect, use the Rapid Rinseless Wash as a drying aid. Spray a small amount onto a wet panel after washing and dry the surface with a drying towel.
A versatile, economical rinseless wash that cleans safely without much water, leaves a streak‑free, glossy finish, smells pleasant and is easy to mix and use—ideal for quick touch‑ups, holidays or as a waterless emergency cleaner.
1 - 3 of 5 reviews
Makkelijk auto schoonmaken
Rapid Rinseless Wash is een erg handig product voor het snel en veilig reinigen van een auto zonder veel water te gebruiken. Het maakt het vuil goed los en laat een schoon, streeploos resultaat achter. Ideaal voor tussentijdse wasbeurten of wanneer een gewone wasbeurt niet mogelijk is. Een praktische oplossing, want blijkbaar vonden mensen emmers vol water toch iets te efficiënt.
Koray - 20/07/2026
Topproduct
Product op vakantie meegenomen om snel de wagen zonder veel water te wassen. Mooi resultaat zonder swirls. Zeker aan te raden als je snel op vakantie je wagen wil opfrissen.
Kristof - 05/07/2026
Top rinseless
Gebruik deze rinsseless werkt erg goed, gebruikte eerst de versie van P&S voor mijn wekelijks was beurt die was erg dik en moeilijk te mengen. Deze van koch chemie is super makkelijk en ruikt ook nog eens lekker.
Patrick - 31/01/2026
