Star Sprayer 28/400
Art. nr. 999001
4.0 (8)
Koch-Chemie Star Sprayhead - The professional standard for spraying.
The Koch-Chemie Star Sprayhead is a high-quality and durable spray head, designed for the even and efficient application of various cleaning and care products. This spray head is the perfect addition to Koch-Chemie's 1-litre bottles and guarantees reliable performance, even with frequent use.
Its robust design ensures a long service life, while the adjustable spray pattern allows for switching between a fine mist and a powerful jet. This makes the spray head versatile for different applications, from misting detailer sprays to applying wheel cleaners. Furthermore, the ergonomic design ensures comfortable operation.
Product number 999001
  1. Screw the spray head onto a compatible 1-litre bottle.
  2. Twist the nozzle to set the desired spray pattern (mist to jet).
  3. Squeeze the trigger to apply the product.
  4. After use with chemicals, rinse the spray head with water to extend its lifespan.
Tip: For an extra fine mist, for example when using an interior cleaner, keep the nozzle almost completely closed. Close sprayer to prevent leakage due to overpressure.
Koch-Chemie GmbH
Einsteinstraße 42
59423 Unna, Duitsland
Top sprayer
Heb meerdere van deze sprayers in gebruik (zowel op Koch flessen, maar ook op andere merken), werkt prima! En Chemical en Solvent resistant!
Chiel - 29 July 2025
Zeer slecht
Sprayer op de QS fles gezet en helaas na een paar keer een fijne mist sprayen begint het product al langs de sprayer te lekken over je handen. Sprayer met water gespoeld, en ook met de spuitkop wat meer open gedraaid lekt het gelijk. Niet wat ik ervan had verwacht.
Wilfred - 18 July 2025
