- Ceramic wash and wax
- Extreme water beading
- Enhances surface slickness
- Safe for all coatings
Meguiar’s Hybrid Ceramic Wash & Wax - Clean and protect with advanced ceramic technology in one wash.
This premium car wash soap delivers a dual-action performance by lifting dirt while adding a layer of Hybrid Ceramic protection. The specialized formula ensures that contaminants are gently removed without stripping existing wax. Simultaneously, it deposits a SiO2-based coating that provides extreme water beading and a slick finish.
The added lubricity makes the washing process safer for the paint and simplifies the drying stage as water rolls off the surface effortlessly. It is an ideal solution for maintaining ceramic coatings or adding a quick boost of protection to any glossy paint finish. The result is a clean, streak-free shine with professional-level protection.
| Product number: | G264848 |
Ensure the vehicle is cool to the touch and parked in the shade.
Rinse the vehicle thoroughly with water to remove loose debris.
For bucket washing, mix 2 oz of product per gallon of water. For foam cannon use, a 1:6 dilution ratio is recommended.
Wash the vehicle section by section using a high-quality microfiber wash mitt.
Rinse each section immediately after washing, starting from the roof and working downwards.
Dry the vehicle immediately after the final rinse with a clean drying towel to prevent water spotting.
Tips
Use the two-bucket method (one for soapy water, one for rinsing the mitt) to minimize the risk of swirl marks.
Applying the product via a foam cannon provides superior lubrication and helps encapsulate dirt more effectively before physical contact.
Snel leverbare, prettige shampoo die goed reinigt, een mooie glans en langdurige waterafstotende beschermlaag achterlaat; ruikt fris, schuimt weinig maar werkt effectief. Helpt vuil los te maken en droogt gemakkelijk. Fles doseert wat moeilijk.
2 - 3 of 5 reviews
Doet goed zijn werk
Hele goede schampoo om je waxlaag te boosten door al het stof was mijn auto erg vies heb hem vorige week met dit gewassen erg fijn meteen een waterafstotende laag erop en ruikt ook lekker lijkt wel citrus enig nadeel niet het produkt maar de fles je kan moeilijk doseren omdat dit erg dun is dan vind ik de buble gum schampoo fijner omdat het dikker is maar een hele fijne schampoo doet wat er beloofd word
Mooie glans.
Fijn product en zeer snel geleverd, ook in België.
