Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
| Product number | MPCK |
| Product type | Spuitpistool |
- Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
- Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
- Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
Ja, er zijn zowel lange als korte verlengstukken beschikbaar.
De opzetstukjes hebben verschillende graden, waarmee je de kracht van de waterstraal bepaalt:
- 15° (rood) – sterk, voor hardnekkig vuil
- 25° (groen) – medium kracht, voor carrosserie
- 40° (wit) – mild, voor gevoelige oppervlakken
- 65° (zwart) – lage druk, lijkt op een tuinslang
Dat is de Nilfisk-aansluiting.
Bij het product vind je plaatjes waarmee je kunt zien of hij op jouw hogedrukreiniger past. Bij twijfel kun je contact opnemen. Let op: hij past niet op de Parkside.
Heel wendbaar en ideaal voor kleine of laagliggende delen zoals wielkasten en velgen. Geen lompe lange spuitstukken en je kunt de spraykopjes snel verwisselen dankzij de quick release.
Ja, als je de blauwe behuizing hebt. Hiermee kun je bijvoorbeeld wisselen van Kärcher naar Nilfisk.
Dat is de Quick Release Type 3 connector.
Veel eerder moeten doen
Ik heb een goede HD reiniger maar sta al jaren te martelen met een lange vaste spuit. Dit geeft je zoveel meer wendbaarheid en bespaart tijd. Zeker icm de monello foamlans met quick connector. Handig met de verschillende opzetstukken met verschillende hoeken
Prima apparaat
Prima apparaat, lekker handzaam en eenvoudig te gebruiken.
