Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
| Product number | MPCN |
| Aansluiting | Nilfisk |
| Product type | Spuitpistool |
- Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
- Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
- Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
makita
kan ik dit pistol gebruiken op mijn makita hogedrukreiniger??
Kwaliteitsproduct
Zeer degelijk product; zit goed in elkaar en maakt een solide indruk. De Quick release koppeling voor Kärcher werkte wat stroef, ik moest flink wat druk uitoefenen om de slang in het pistool te krijgen, maar uiteindelijk gelukt. Ook de bijgeleverde opzetstukjes klik je er gemakkelijk op. Persoonlijk vond ik de rode een erg harde straal geven; zou ik niet gebruiken voor de lak. Jammer dat ik de gele nozzle gemist heb tijdens het bestellen, want die zou ik er graag nog bijhebben voor het afspoelen van bijv. Autglym seal. De lange gebogen lans is erg handig om de onderkant van de auto te reinigen; zou ik altijd meebestellen! Verder erg tevreden over dit product.
Veel eerder moeten aanschaffen.
Had al jaren eerder dit moeten aanschaffen. Makkelijk draaien en heel krachtige straal
