Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
With the Monello Pistola Corta, you replace the standard spray gun with long attachments from your pressure washer for a short, maneuverable gun from Monello. This will make you much more maneuverable while hosing down your car. The Pistola Corta allows you to use the pressure washer in places that are normally difficult to reach, such as wheel wells and rims.
Quick Release
The Monello Pistola Corta has a so-called 'quick release' connection. This means that you can change from one attachment to the other or mount your foam lance on the pistol within a few seconds. You simply pull the jacket towards you so the attachment can be removed. Then you mount another attachment or a foam lance with quick release coupling.
The Pistola Corta comes with an extra quick release coupling for the most common foam lances. If you already have a Monello Lancia 2.0, it’s recommended to order an extra adapter for the quick release connection, because the existing connection can be difficult to remove from the already mounted connection.
Attachments for the right job
In addition to its maneuverability, the Pistola Corta allows you to change attachments quickly and easily. You get 4 attachments that each give a range in a different number of degrees each with its own color so you can easily choose the right attachment. Attachments of 0° (black), 15°(red), 25°(green) and 40° (white) are included. The wider the impeller, the milder the cleaning effect. For hosing down the car body, you mainly use the 25° and 40° attachments.
Connection
The Pistola Corta can be delivered with a connection for a Kärcher K-Series or Nilfisk connection for the high pressure hose. The Nilfisk connection is used by AVA, Bosch and Black & Decker, among others. The Kärcher connection can be used if the rubber O-ring of the connection is 8.8-9 mm. For the Nilfisk connection this is 7.8-8 mm.
Quality
The Pistola Corta is made of high quality materials and feels very solid. The connection and quick release coupling are made of high quality metals and the handle is equipped with anti-slip so you have optimal grip during use.
| Product number | MPCN |
| Aansluiting | Nilfisk |
| Product type | Spuitpistool |
- Remove the old gun from the high pressure hose. Look in the manual of your pressure washer how to do this.
- Click the high pressure hose into the connection of the Pistola Corta, check well that it's clicked tight. Always test the gun away from the car before using it to make sure the hose is properly attached.
- Pull the sheath towards you and attach one of the attachments to the foam lance. Again, check that the attachment is securely seated in the quick release connection.
Even wennen maar werkt veel fijner
Lang getwijfeld maar had ik eerder moeten doen. Werkt veel fijner dan zo’n lange lans (Nilfisk). Ik sta nu dichter op het plaatwerk en zie dus ook meer. Wel even wennen qua gebruik (reageert soms anders dan lans en is veel beweeglijker). Robuste uitvoering en met verschillende spuitmonden.
Werkt gewoon
Zoals in de titel: het werkt gewoon!
Lekker in de hand, handig om de vorm van de straal en de sterkte aan te passen. Ideaal voor een meer gecontroleerde reiniging van je voertuig.
Reeds getest op een auto, motor en niets van opmerkingen kunnen vinden. Gebruik hem in samenwerking met de K4 Full Control van Kärcher. Enigste minpunt is misschien het verlies van de sterkte te kunnen aanpassen op de gun…. Stoort mij eerlijk gezegd niet. Kortom waar voor je geld. Hopelijk komt carclean ook met misschien verlengstukken voor als je toch wat langer wil of een tool om de bodem te reinigen van voertuigen?
Fijn en handig pistool!
Op aanraden, en met een mooie actie, gekocht bij Carclean vanwege een probleem met de lancia 2.0 icm mijn Ava hogedrukreiniger. Zeer tevreden van dit pistool, is net wat beter als het standaardpistool van de Ava dewelke ook zeer fijn is.
