Foam Detail Brushes - 5-pack
Art. nr. 20032094
The Nuke Guys Foam Detail Brushes are your secret weapon for treating those hard-to-reach spots in your car, such as air vents and plastic trim. With this set of five soft foam brushes, you can work with great precision, allowing you to care for your car down to the smallest detail.
Key features:
  • Set of 5 brushes: Always the right size at hand for every job.
  • Soft foam: Safe for all surfaces; prevents scratches and damage.
  • Wooden handle: Comfortable to hold for optimal control.
  • Flexible design: The brushes can be compressed to clean even the hardest-to-reach areas and then return to their original shape.
  • Easy to use: Suitable for both wet and dry cleaning; can be used with or without cleaning agents.
Whether you're a seasoned detailer or just want to keep your car in top condition, these foam brushes make treating tight spaces a breeze!
Product number: 20032094
  • Material: Soft foam
  • Handle: Wood (length 10 cm excluding foam piece)
  • Quantity in set: 5 pieces
  • Application: Interior detailing, hard-to-reach places
  • Flexibility: Can be compressed and returns to its original shape
  • Foam piece dimensions: 45 x 25 x 15 (length x width x thickness)
Nuke Guys
Boschweg 3
63741 Aschaffenburg, Duitsland
  1. Preparation: Ensure the surface to be cleaned is free of loose dirt and dust.
  2. Application of cleaning agent: If desired, apply an appropriate cleaning agent to the brush or directly onto the surface.
  3. Treating: Use the brush to gently treat the area. Thanks to the flexible foam, you can compress the brush to reach tight spaces.
  4. Aftercare: Wipe the cleaned area with a clean cloth to remove excess moisture or cleaning agent.
  5. Brush cleaning: Rinse the brushes after use with warm water and let them air dry, so they are ready for the next cleaning session.
2 - 3 of 4 reviews
perfect
Dit product weer echt top voor die kleine hoekjes waar je normaal net niet bij komt. Vooral voor de lucht roosters zijn ze top.
Tim - 11/02/2025
  • Flexible
    Foam detail brushes
Reaches even the tiniest corners
Flexible foam technology
The Nuke Guys Foam Detail Brushes are made from a soft foam material that perfectly suits any detailing task. Thanks to the flexible design, the brushes can easily be compressed, allowing you to clean even the most hard-to-reach places effortlessly. After use, the brushes immediately return to their original shape, ensuring long-lasting and effective performance. Whether it’s air vents, buttons, or other narrow spaces, these foam brushes make applying a coating significantly easier.
For all hidden spots
Hard to reach? No problem!
These foam brushes are the ultimate solution for hard-to-reach places. The narrow, compact heads of the brushes are specifically designed to fit into the smallest cracks and crevices. Think, for instance, of the grille, air vents, or small details on the dashboard. Thanks to the soft foam, you don’t have to worry about causing any damage while still achieving excellent results. With the Nuke Guys Foam Detail Brushes, you can now reach every spot with ease!
Five times perfection
Complete set with stylish handles
The Nuke Guys Foam Detail Brushes come in a convenient set of five, ensuring you always have the right brush for any task. Each brush features a fine wooden handle that provides a firm grip and a comfortable cleaning experience. The natural wood also adds a stylish touch, making this set not only functional but also a great addition to your detailing collection. With five brushes, you’re ready for any detailing job, big or small!
