Bold N Bright Tire Dressing - 946ml
- Water-based car tire dressing
- Non-greasy and non-sticky
- Protects against UV radiation
- Zero paintwork sling effect
Poorboy's World Bold N Bright - Revitalizes dull and faded tires.
Poorboy's World Bold N Bright is a water-based tire dressing that nourishes the rubber while providing a deep black finish. The liquid absorbs quickly and leaves absolutely no greasy or sticky residue behind. This prevents new road grime from quickly adhering to the surface again. Furthermore, the formula is equipped with UV blockers to prevent further drying and brown discoloration caused by sunlight.
The dressing is versatile and can create both a subtle satin finish and a deep high gloss. A major advantage is that the product is dry to the touch, effectively preventing black splatters from slinging onto the car paint while driving. Because it is a water-based formula, the longevity will decrease slightly faster after heavy rain or intensive washes compared to a silicone-based dressing.
| Product number: | PB-BNB32 |
| Consistency: | Liquid |
Ensure a dry and thoroughly cleaned tire surface for the best results.
Apply the liquid to an applicator pad or spray directly onto the rubber.
Spread the dressing in a thin, even layer across the sidewall of the tire.
Wipe off any excess product with a clean cloth.
Tips
Wipe the treated surface immediately with a microfiber towel for a subtle, matte factory look.
Allow the product to air dry completely without wiping to achieve a maximum, striking high gloss.
Nee, mits juist verwerkt heeft Bold N Bright geen "sling-effect". Doordat het product op waterbasis is en snel intrekt in het porieuze rubber, vliegen er tijdens het rijden geen vette spetters tegen de lak van je deuren of achterbumper.
Bold N Bright is een product op waterbasis. In tegenstelling tot goedkope dressings op basis van zware siliconen, wordt het rubber niet vettig of plakkerig. Zand en vuil hechten zich hierdoor niet aan de band. Bovendien reinigt het lichte vervuiling tijdens het aanbrengen en droogt het volledig droog op.
2 - 3 of 31 reviews
Top product
Goeie spul Spat niet achteraf. Geeft een mooie glans op de bandenn
bold n bright tire dressing-46ml
niet slecht maar er zijn er beter
Dhr
Goed verwerkbaar. Mooi resltaat. Ruikt lekker
