Ultra Glaco Glass Sealant - 70ml
Art. nr. 04146
5.0 (35)
  • For crystal-clear windows in any storm
    A must-have for your car windows
Rain dance? We'd rather not.
Superior Water Repellency
Ultra Glaco creates an invisible yet incredibly strong water-repellent coating on your car windows. Thanks to advanced Fusso technology, rainwater beads off the glass as soon as you reach 45–60 km/h. Your visibility remains clear, even during heavy downpours, which is not only more comfortable but also safer. This coating actively repels rain, snow, dirt, and even ice formation, keeping your windows much cleaner and reducing the need to use your wipers as often.
Kleding, Handschoen, E-scooter, vervoer, Voertuig
Handschoen, Volwassene, Mannelijk, Man, Persoon
Long live Glaco!
Lasts up to 12 months
Forget about reapplying glass coating every month. Ultra Glaco remains effective on your car windows for up to a year, even under harsh weather conditions or frequent washes. The coating bonds firmly to the glass surface and withstands wipers, cleaning agents, and UV radiation. This means less maintenance and year-round crystal-clear visibility. Apply once, enjoy for a year.
Click, twist, apply!
Convenient All-in-One Application
Ultra Glaco isn’t just effective—it’s also super easy to use thanks to the built-in felt applicator. No hassle with cloths, pads, or separate bottles—just twist off the cap and apply the product directly to the window. The felt surface ensures an even distribution of the coating, without mess or streaks. This makes application quick and effortless, even for beginner detailers. Perfect for those who want both convenience and great results.
Soft99 Ultra Glaco is a powerful glass coating that protects your car windows for up to 12 months against rain, dirt, and ice. Utilizing advanced Fusso technology, it forms a durable, water-repellent layer resistant to wipers, car washes, and cleaning agents.
The integrated felt applicator makes application easy and clean. At speeds of 45-60 km/h, Ultra Glaco causes water to bead off the windshield, enhancing visibility during rainy drives. It also simplifies the removal of insect residues and ice in winter.
For optimal results, it's recommended to thoroughly clean the glass beforehand using a dedicated glass cleaner like Glaco Glass Compound Roll On.
Product number 04146
Consistency Liquid
Durability Long
Product form Squeeze bottle
Suitable for glass Yes
Suitable for material Glass
Volume Small (0 - 400ml)
  1. Wash the windows thoroughly and make sure they are completely dry. If necessary, use a glass polish like Glaco Glass Compound Roll On.
  2. Shake the bottle well with the cap on.
  3. Remove the cap and press the felt applicator onto the dry glass. Gently squeeze the bottle to release the product and apply it evenly using a crosshatch motion.
  4. Allow the product to dry for 5–10 minutes until a white haze appears.
  5. Wipe away the haze with a clean, dry microfiber cloth.
  6. Keep the glass dry for at least 12 hours to allow the coating to fully cure.
Met één verpakking Ultra Glaco kun je ongeveer 4 tot 5 auto’s volledig behandelen (voorruit, zijruiten en achterruit). Natuurlijk hangt het af van de grootte van je auto en hoe royaal je het aanbrengt.
Gebruik een pluisvrije glasdoek of een schone microvezeldoek die geschikt is voor glas. Daarmee voorkom je vlekken of strepen, en houd je het zicht perfect helder.
Laat het minimaal 12 uur droog blijven na het aanbrengen. Geen regen, geen ruitenwissers, en liever ook niet rijden. Zo krijgt de coating de kans om goed uit te harden – en dat is cruciaal voor een langdurig effect.
Reinig de ruiten grondig met een speciale glasreiniger zoals Glaco Glass Compound Roll On. Zo hecht de coating beter en gaat ‘ie langer mee.
Nee, liever niet. Op spiegels krijg je wel ‘beading’ (druppelvorming), maar daar is geen rijwind om de druppels weg te blazen. Het resultaat? Een wazig zicht. Gebruik liever een specifieke coating voor spiegels of laat ze onbehandeld.
Vanaf zo’n 45-60 km/u parelt regenwater vanzelf van je ruit af – je hebt dus vaak nauwelijks ruitenwissers nodig. Ook insectenresten en ijs verwijder je makkelijker dankzij de gladde coatinglaag.
SOFT99 Corporation
Tanimachi 2-6-5
540-0012 Osaka, Japan
Soft99 Europe
ul. Kramarska 3/5
61-765 Poznań, Polen
Top
Na diverse andere producten gebruikt te hebben deze eens gekocht. En moet zeggen aanbrengen is een eitje dus dat is al een voordeel. En het werkt erg goed het water begint al goed vangnet voorruit te lopen. Bij iets van 60 km/u. Ook bij langzamere snelheid vormt de regen dikke druppels die het zicht een stuk beter maakt.
Menno - 10 November 2022
Japanse kwaliteit
Het was dezelfde als degene die ik in Japan gebruikte, dus ik kon het met vertrouwen gebruiken.
Heel fijn.
Thomasse - 26 October 2022
Fantastische raam sealer!
Aangebracht na Glaco Compound Roll On te hebben gebruikt!
Aanbrengen op (zeer schone) droge ramen, in ruitpatroon (boven naar beneden, links en rechts). Waar het product is aangebracht zie je een lichte 'haze' (neveleffect), dus weet je dat je het behandeld. Circa 15 minuten wachten, afhankelijk van temperatuur/weer. Daarna uitboenen met een schone, droge doek. Daarna wordt geadviseerd circa 12 uur standtijd te geven, zodat het goed kan hechten aan het raam. Maar daarna: 1 woord geweldig. Het water vliegt al bij circa 60 kmh van de ramen af. Nu ongeveer 1,5 maand op mijn ramen maar werkt nog alsof ik het gisteren heb aangebracht. Ben benieuwd hoe lang het effect blijft. Product is een blijvertje voor mij (doei Rain-X)!
IT - 12 November 2019
