Rain dance? We'd rather not.
Superior Water Repellency
Ultra Glaco creates an invisible yet incredibly strong water-repellent coating on your car windows. Thanks to advanced Fusso technology, rainwater beads off the glass as soon as you reach 45–60 km/h. Your visibility remains clear, even during heavy downpours, which is not only more comfortable but also safer. This coating actively repels rain, snow, dirt, and even ice formation, keeping your windows much cleaner and reducing the need to use your wipers as often.
Long live Glaco!
Lasts up to 12 months
Forget about reapplying glass coating every month. Ultra Glaco remains effective on your car windows for up to a year, even under harsh weather conditions or frequent washes. The coating bonds firmly to the glass surface and withstands wipers, cleaning agents, and UV radiation. This means less maintenance and year-round crystal-clear visibility. Apply once, enjoy for a year.
Click, twist, apply!
Convenient All-in-One Application
Ultra Glaco isn’t just effective—it’s also super easy to use thanks to the built-in felt applicator. No hassle with cloths, pads, or separate bottles—just twist off the cap and apply the product directly to the window. The felt surface ensures an even distribution of the coating, without mess or streaks. This makes application quick and effortless, even for beginner detailers. Perfect for those who want both convenience and great results.
Soft99 Ultra Glaco is a powerful glass coating that protects your car windows for up to 12 months against rain, dirt, and ice. Utilizing advanced Fusso technology, it forms a durable, water-repellent layer resistant to wipers, car washes, and cleaning agents.
The integrated felt applicator makes application easy and clean. At speeds of 45-60 km/h, Ultra Glaco causes water to bead off the windshield, enhancing visibility during rainy drives. It also simplifies the removal of insect residues and ice in winter.
For optimal results, it's recommended to thoroughly clean the glass beforehand using a dedicated glass cleaner like Glaco Glass Compound Roll On.
| Product number | 04146 |
| Consistency | Liquid |
| Durability | Long |
| Suitable for glass | Yes |
| Suitable for material | Glass |
| Type of protection | Synthetic (sealant) |
| Volume | Small (0 - 400ml) |
- Wash the windows thoroughly and make sure they are completely dry. If necessary, use a glass polish like Glaco Glass Compound Roll On.
- Shake the bottle well with the cap on.
- Remove the cap and press the felt applicator onto the dry glass. Gently squeeze the bottle to release the product and apply it evenly using a crosshatch motion.
- Allow the product to dry for 5–10 minutes until a white haze appears.
- Wipe away the haze with a clean, dry microfiber cloth.
- Keep the glass dry for at least 12 hours to allow the coating to fully cure.
Resultaat is goed te zien
Deze week eerst de ramen schoon gemaakt met een compound van glaco en toen deze Sealant er op gezet.
Makkelijk te verwerken en ik zag een duidelijk verschil tussen mijn behandelde en onbehandelde ruiten.
Ik had gelukkig wel eerst de auto (en dus de ruiten) warm gestookt omdat ik pas na het schoonmaken met de compound ontdekte dat je boven een bepaalde temperatuur moest zitten.
De volgende keer wacht ik op hogere buitentemperatuur maar voor nu ben ik tevreden met het resultaat.
Geweldig
Aangebracht na Glaco compound en daarna een nachtje laten uitharden in de garage. Nu drie maanden later werkt het nog als op dag één.
super spul
Ik heb de Soft99 Ultra Glaco toegepast op de voorruit en zijruiten van mijn auto, na een grondige reiniging. De applicatie verloopt vlot: het flesje heeft een ingebouwde applicator-pad, waardoor je snel een egale laag kunt aanbrengen.
