Först Citrus Pre-Cleaner-1000ml
- Cleaner with natural oils
- Perfect for tough cleaning jobs
- Pleasant fragrance
- Economical to use
The first choice for tough cleaning jobs
When your car is really dirty, or it's time for spring cleaning, Först, a citrus Traffic Film Remover (TFR), makes the task easy.
Formulated with natural orange oil, it not only boosts cleaning power but also smells amazing!
Apply undiluted to areas that need extra attention, let the product sit for a moment to work its magic, and then rinse thoroughly with water.
Först Citrus Pre-Cleaner has more cleaning power than Snö Snow Foam because it doesn't have added air, has a higher pH, and works at full strength. The downside is that your wax and sealant may not tolerate it as well.
It's often unnecessary and wasteful to spray the entire car with Först Citrus Pre-Cleaner. Use it only on the areas that really need it, usually the lower parts of the car, like bumpers and sills. Först Citrus Pre-Cleaner is also perfect for cleaning door jambs or under the hood.
| Product number: | STFO10S |
- Spray Först Citrus Pre-Cleaner evenly on the areas you want to treat.
- Allow the product to work for 2-5 minutes, then rinse it off with water, preferably using a pressure washer.
- Do not let it dry.
Log in
5 - 3 of 18 reviews
Haalt vuil naar boven
Dit product kun je opsprayen, even in laten werken en vervolgens met hoge druk weer afspoelen. Het haalt het vuil naar boven en weekt vliegen etc. los. Makkelijk aan te brengen en ruikt goed. Heb het nu voor de tweede keer gekocht.
Ideaal voor zwaar vervuilde stukken
Ideaal voor zwaar vervuilde stukken. Doet z’n werk boven verwachting. Geur is ook zeer prima! 10/10 would buy again.
Topprestatie
Gebruik het voor erg vervuilde delen van de auto, zeker zoals nu in de winter; erg goede pre wash! Zuinig in gebruik!
