MegaFlow 100 - Super Power Turbofan
Art. nr. WB-MF100
4.6 (18)
  • Blow, dry and clean in turbo mode
    Your new favorite gadget
Pocket-sized wind power
Powerful cordless mini-blower
The MegaFlow 100 delivers serious blowing power in a compact size. With a powerful motor reaching up to 150,000 RPM and an airspeed of nearly 300 km/h, no task is too big. The built-in 6000 mAh battery offers up to 100 minutes of use on the lowest setting, allowing you to work wirelessly anywhere and anytime. Whether you need to remove dust, dirt or crumbs, this mini-blower handles it effortlessly, without being tied to a power outlet.
Goodbye water drops
Ideal for drying grilles and wheels
Wet wheels, tricky grilles and mirror housings that always hide a drop of water? With the MegaFlow 100 you can dry them completely in seconds. This prevents annoying water spots on the paintwork and ensures no surprise drips after washing. Thanks to the high airspeed and multiple nozzle attachments, you can easily reach every awkward corner, making sure your car leaves not only clean but also perfectly dry.
Crumbs, dust and chaos
Perfect for interior cleaning
From air vents to the gaps between seats, the MegaFlow 100 quickly takes care of dust, crumbs and other stubborn debris inside the car. Its compact design and precise airflow let you clean even hard-to-reach spots without damaging components. Perfect for keeping your car interior fresh and tidy, and also great for cleaning delicate electronics or keyboards. With the right attachments, every corner is spotless in no time.
WOLFBOX MF100 - Powerful blower in a compact size
The WOLFBOX MF100 is a versatile and powerful cordless mini-blower, designed to effectively remove dust and debris from hard-to-reach areas. Ideal for cleaning car interiors such as air vents, gaps, and seams, but also suitable for electronics and other delicate surfaces.
Easily blow water away from grilles, wheels, mirrors, and other tricky-to-dry areas to prevent drips and water spots on the paintwork later on.
Thanks to its powerful motor and the various included nozzle attachments, no task is too big. The built-in battery ensures long-lasting, wireless convenience anytime and anywhere. In addition to car use, the MegaFlow 100 is also perfect for inflating items such as beach balls, inflatable boats, and more.
The MegaFlow 100 has 3 speed settings so you can always choose the right airflow for the job. The mini-blower spins at up to 150,000 revolutions per minute and reaches an airspeed of nearly 300 km/h! Thanks to its overheating protection, the blower will automatically reduce power on the highest setting after prolonged use to prevent damage.
With its 6000 mAh battery, the mini-blower runs for up to 100 minutes on the lowest setting. When used exclusively on the highest setting, the runtime is approximately 10 minutes. You can recharge the blower via the included USB cable (without adapter).
Supplied with various nozzle attachments and a fabric storage bag.
Product number WB-MF100
  • Ensure the battery is fully charged before use.
  • Press and hold the round button at the back until the blue lights turn on.
  • Press the round button again to adjust the power level.
  • Press the oval button at the front to start the device. On the highest setting, the oval button must be held down.
On the highest setting, the blower will reduce power after a while. This is normal and a safety feature to prevent overheating. Allow the device to cool down before using maximum power again.
Only charge the device once it has cooled down, and do not use it while it is charging.
Tussen de 10 en 100 minuten, afhankelijk van de stand. Op volle kracht 10 minuten, maar die gebruik je zelden continu.
Betere bouwkwaliteit, hoogwaardige accu’s en een ventilator van metaal in plaats van plastic.
Nee. De accu en blaaskracht zijn hier niet op afgestemd, en de opening is te klein voor grote oppervlakken.
Perfect voor het drogen van velgen, roosters, grillen, spiegels, raamstijlen en logo’s – alle plekken waar water achterblijft en later vlekken veroorzaakt. Ook ideaal om stof uit het interieur en ventilatieroosters te blazen.
Hong Kong Tanglian Trading Co., Limited
Cheers House 45-51
Kowloon, Hong Kong
Handig hebbedingetje, maar....
Handig hebbedingetje , mooi voor hij afblazen van dashboard , roosters e.d.
Echter lijkt ik pech te hebben met een exemplaar wat niet 100% in orde lijkt.
Blaaskracht is niet wat ik ervan had verwacht ( op basis van review video's van anderen e.d. ).
Het viel al snel op dat de accu erg snel leeg was ( Na =+/- 40 sec. op max. terug van 4 naar 2 ledjes op de accu indicator en na +/- 5 min. volledig leeg ) en tevens lijkt hij ook niet volledig op te willen laden ( 4e ledje blijft maar knipperen , al hangt hij al de hele dag aan de lader ).
Diverse laders / laadsnoeren gebruikt met telkens hetzelfde resultaat.
Mijn exemplaar is voorlopig weer retour naar Carclean HQ voor nader onderzoek.
Ik weet eerlijk gezegd nog niet of ik hem nog terug wil hebben....
Edit: Ook het vervangende exemplaar heeft inmiddels de geest gegeven!!
Je kan wel eens pech hebben, maar 2x exact hetzelfde probleem ?!?
Wat mij betreft nooit meer :(
Pascal - 13 September 2025
Antwort des Online-Shops: En toch, zoals ook gemeld per mail, ben je tot nu toe de enige met een retour of problemen. Uit honderden exemplaren inmiddels.
leuk winderig nuttig hebbedingetje
aantal dagen in mn bezit en ik moet zeggen voor zn afmeting komt er een goeie blaaskracht uit, geterst op mn robot stofzuiger en binnen no time spik en span, ben benieuwd op velgen grill deurscharnieren en grepen maar dat zit vast goed.
Alex - 31 August 2025
Handig apparaat
Goed apparaat
Handig in gebruik voor kleine dingen
Gebruik hem zelf om de fiets snel even droog te blazen, roosters van auto zowel binnen als buiten.
Op hoogste stand gaat uiteraard de accu sneller leeg maar valt me nog best mee hoe snel dat is.
Erg tevreden, blij met de aanschaf
Erik - 26 August 2025
