Avalanche Snow Soap 1000ml
Art. nr. AF-AV1000
Citrus-Infused Formula
With just a small amount of this ultra-concentrated Avalanche Snow Foam, you'll achieve impressive results. A few inches in the foam lance bottle, topped up with water, is enough to create a thick, long-lasting foam that thoroughly cleans your paintwork of surface dirt, grime, and stubborn contaminants.
Spray and Rinse Formula
This citrus-infused formula is packed with advanced surfactants designed to safely lift and encapsulate harmful particles and traffic film. These particles are then trapped in the foam and can be easily rinsed away without damaging sensitive surfaces. Simply apply the foam over the entire vehicle, let it dwell, and rinse away the contaminants without making contact with the vehicle.
pH-Neutral Snow Foam
Avalanche safely and effectively cleans every exterior surface, from paint and vinyl to glass, trim, and wheels. This powerful cleaner is also safe for wax, sealant, and coatings, meaning it won’t strip or damage your protective layers.
Product number: AF-AV1000
EUH208: Contains (R)-p-mentha-1,8-dieen; d-limoneen (5989-27-5). May produce an allergic reaction.
H315: Causes skin irritation.
  • Vul een literfles met 2.5-5 cm Avalancia Snow Foam en de rest met water.
  • Breng de foam aan van beneden naar boven en laat het intrekken voordat je de foam afspuit met hoge druk.
  • Foam niet op laten drogen op het lakwerk.
Consistently praised Avalanche snowfoam delivers thick, long-lasting foam that lifts dirt effectively, is safe for waxes/sealants, smells pleasant and offers great value — a top choice for strong pre-wash performance.
2 - 3 of 7 reviews
Perfecte voorwas
Gebruikte hiervoor Monello Artico Magico, maar was op zoek naar iets sterkers voor als de wagen nét iets vuiler is (zeker in de wintermaanden). Deze Avalanche vervult die rol perfect! Goeie sterke voorwas om grof vuil er perfect van te krijgen.
Gaëtan Massün - 08/02/2021
Ik heb tot nu toe de Artico Magico, Apple iFoam en deze getest en vind de Avalanche de beste van de 3. Schuimt goed, neemt heel goed vuil mee en valt mee qua prijs. Een blijver dus.
Jef - 04/05/2020
uitgebreide test mbt tot Ph: http://www.detailingworld.co.uk/forum/showthread.php?t=346974 Conclusion: pH can be important for your own safety, but has little to no effect on strong and weaker waxes, sealants or AIO.
Rob Mulder - 25/02/2017
Works together with
Monello Lancia Foam Lance - Karcher K-series
  • Foam lance for pressure washers
  • Compatible with almost all pressure washers
  • Produces thicker foam
  • 1L HDPE mixing bottle with measurement scale
€ 59.99
Last chance
Dodo Juice
Snow Commotion Snow Foam Cannon
  • Foamlans voor hogedrukreinigers
  • Op meerdere manieren instelbaar
  • Met snelsluiting
  • Inclusief stevige 1L-fles
  • Met Kärcher K-series connector
  • Professionele kwaliteit
€ 57.99
Has been discontinued
Favorite
IK Sprayers
Foam Pro 2 handfoamer - 1250ml
  • Professionele handfoamer
  • Geschikt voor uiteenlopende vloeistoffen
  • Inhoudsmaten per 250 ml & kleurindicator
€ 33.99
Carclean.com
Fluxx tapkraan 13/38 DIN 38
  • Probleemloos vullen
  • Geen geknoei
€ 4.99
Alternative products
Favorite
Artico Magico Snow Foam - 1000ml
  • Safely loosens dirt
  • Creates nice thick foam layer
  • Safe for waxes, sealants and coatings
€ 15.99
Stjärnagloss
Snö Snow Foam Pre-Wash-1000ml
  • High-foaming snow foam
  • pH-neutral formula
  • Does not affect wax or sealant
  • Pleasant fragrance
€ 18,-
Last chance
Valet Pro
Advanced Neutral Snow Foam 5000ml
  • pH-neutrale formule
  • Reinigt als een alkalische foam
  • Zeer geconcentreerd
€ 41.90
Last chance
Valet Pro
Advanced Neutral Snow Foam 1000ml
€ 16.50
