You can easily reach it
Specially for large vehicles
Washing large vehicles like RVs, SUVs, and vans can be a time-consuming task. The Autofiber Mitt on a Stick Pro makes this chore significantly easier. With its long, adjustable handle and flexible wash mitt, you can effortlessly reach high roofs and hard-to-access areas. This convenient tool is perfect for anyone who loves keeping their vehicle spotless without spending hours stretching or bending. Transform vehicle washing into a comfortable and efficient experience with this ingenious design!
Nice and sturdy
Robustly constructed
The Autofiber Mitt on a Stick Pro is built to last. Its sturdy construction, from the durable handle to the high-quality materials of the mitt, ensures that it can withstand intensive use. The robust connection between the handle and mitt ensures everything stays securely in place, even during vigorous scrubbing. Whether tackling stubborn dirt or simply giving your vehicle a quick refresh, this wash stick is up to the task. Durability and reliability come together in this innovative tool.
Ready for next time
Washable mitt mitt
After a thorough cleaning session, you’ll want your tools ready for the next round. No worries! The wash mitt is easily removable and machine washable. This makes maintaining the Autofiber Mitt on a Stick Pro simple and hygienic. Keep the mitt clean and fresh without needing to replace it after every wash. Wash it, reuse it – it doesn’t get much easier!
AutoFiber Mitt on a Stick Pro Plus - Effortless washing at any height
Washing tall or large vehicles like an SUV, van, caravan, or boat is often a challenge. The roof and other hard-to-reach areas are easily missed. With the Mitt on a Stick Pro Plus, this is a thing of the past. This tool is specifically designed to clean every part of the vehicle safely and effectively, without the need for a step stool or ladder.
The sturdy, sectional pole provides a long reach, while the soft microfiber wash mitt prevents scratches and safely lifts dirt. The head is adjustable to various angles, making it easy to wash roofs and sloped surfaces. This not only makes the washing process faster but also significantly more comfortable and safer. A clever addition is the 'towel plug' in the head, which also allows any microfiber towel to be secured for tasks like drying the car.
| Product number | MOASPRO-PLUS-SEC3-B-CM |
| Made from material | Microfiber |
| Product form | Telescope |
| Suitable for | Large vehicles |
Monteer de steel tot de gewenste lengte.
Bevestig de meegeleverde washandschoen op de kop.
Dompel de washandschoen in een emmer met autoshampoo.
Was het voertuig van boven naar beneden. Begin met het dak en werk naar beneden toe.
Stel de hoek van de kop bij om gemakkelijk schuine of lage delen te bereiken.
Spoel de washandschoen regelmatig uit in een aparte emmer met schoon water om vuil te verwijderen.
Na gebruik de hoes verwijderen, uitspoelen en laten drogen.
Tip voor de gebruiker:
Voor een optimaal resultaat en om krassen te minimaliseren, is het aan te raden om de twee-emmer-wasmethode te gebruiken. Eén emmer met shampoo en één met schoon water om de handschoen uit te spoelen.
Handig ding
Hij wast niet alleen heel goed, maar de steel die uit elkaar kan is heel handig, ik neem hem mee op vakantie in mijn caravan omdat hij mooi compact kan worden opgeborgen.
Hij is weliswaar duur maar ook erg goed.
Werkt goed en snel
Op m’n buscamper geprobeerd, het dak gaat goed, grote vlakken gaat goed. Randjes dan heb je toch wel een goede washandschoen nodig. Steel kun je in 3 delen in/uit elkaar schroeven met goede foam om de steel. Washmitt past strak met de drukknopen blijft hij goed zitten, past prima in een emmer, washmitt neemt erg goed water op, heb een extra emmer (19liter) er bij gepakt zodat ik gelijk door kon gaan. Als je bv de voorkant van een gril er mee doet, pas dan op dat de mitt niet plots omklapt, dan komt het kunststof draaideel op je lak. Prima om snel grote vlakken te doen, er zat een papier bij dat de swivel functie op het draaigedeelte geblokkeerd is, dit na reviews dat dit lastig zou zijn.
Goed uitgevoerd
Stevig ding. Ook het feit dat het "doek" met stevige drukkers vastzit en niet los kan schieten is vertrouwenwekkend.
