Future Armour High Performance Spray Sealant - 500ml
Future Armour is a technologically advanced spray sealant that has the advantage of being water-based. This means you can use the product on both dry and wet paints, or even as a wingman while rinsing with a pressure washer.
As the name suggests, Future Armour is a technological marvel with one foot in the future. Dodo Juice has received a visit from Mr. Skittles from the year 2039, who has shared all the secrets.
According to Mr. Skittles, there will always be fans of Red Mist because the shine this spray provides is legendary (both now and in the future), but the formula of this product will deliver great results for a fraction of the price, and thanks to the water-based formula, this product is as versatile as it gets.
In fact, “versatile” doesn’t even begin to cover it. Future Armour can be used on paint, plastic, glass, and even metal. Both wet and dry. Use it as standalone protection or as a boost to your wax or sealant.
You can use the product neat, but because it is water-based, you can also dilute it up to 1:10 depending on personal preference. Of course, the product will lose some of its performance after dilution, but with regular use, you’ll hardly notice it. The chance of streaks will be significantly lower with diluted use.
Do you have a foam lance? You can also use Future Armour with it. But be aware that the mesh filter can get clogged more quickly, so always make sure to have a spare filter on hand.
Does it look like rain🌧️ is coming? Preferably wipe the product off with a microfiber cloth so that the rain doesn’t run the product further over your car, causing streaks. Nobody likes that.
The last tip Mr. Skittles gave before he returned to the year he came from is that Future Armour can also be used as a wheel wax; how easy is that!
| Product number | DJFA500 |
| Consistency | Liquid |
| Durability | Medium |
| Gloss Level of Surface | Glossy |
| Product form | Spraybottle |
| To be applied wet | Yes |
| Type of protection | Synthetic (sealant) |
Wet Use:
- After washing and rinsing, mist onto the still damp paint
- Immediately rinse off with a pressure washer
- Then dry.
- Work panel by panel and do not let it dry.
Dry Use:
- Apply using a microfiber pad or cloth
- Immediately buff
- Do not let it dry.
* Note when dealing with damaged or old paintwork. Always test first in an inconspicuous area.
Top spray sealant
Future Armor van Dodo Juice is een geweldige spray sealant om je poetsbeurt mee af te sluiten of om je bestaande wax of coating laag mee te versterken.
Topproduct
Best wel tevreden over deze aankoop. Gebruikte hiervoor Monello, maar dat product moet je heel snel afspuiten of je krijgt plekken. Bij dit product helemaal niet het geval.
Makkelijk en goed spul
Na wassen van de auto gebruikt zoals beschreven op de bijgevoegde handleiding. Mooie glans en doet wat het belooft.
