Future Armour High Performance Spray Sealant - 500ml
Future Armour is a technologically advanced spray sealant that has the advantage of being water-based. This means you can use the product on both dry and wet paints, or even as a wingman while rinsing with a pressure washer.
As the name suggests, Future Armour is a technological marvel with one foot in the future. Dodo Juice has received a visit from Mr. Skittles from the year 2039, who has shared all the secrets.
According to Mr. Skittles, there will always be fans of Red Mist because the shine this spray provides is legendary (both now and in the future), but the formula of this product will deliver great results for a fraction of the price, and thanks to the water-based formula, this product is as versatile as it gets.
In fact, “versatile” doesn’t even begin to cover it. Future Armour can be used on paint, plastic, glass, and even metal. Both wet and dry. Use it as standalone protection or as a boost to your wax or sealant.
You can use the product neat, but because it is water-based, you can also dilute it up to 1:10 depending on personal preference. Of course, the product will lose some of its performance after dilution, but with regular use, you’ll hardly notice it. The chance of streaks will be significantly lower with diluted use.
Do you have a foam lance? You can also use Future Armour with it. But be aware that the mesh filter can get clogged more quickly, so always make sure to have a spare filter on hand.
Does it look like rain🌧️ is coming? Preferably wipe the product off with a microfiber cloth so that the rain doesn’t run the product further over your car, causing streaks. Nobody likes that.
The last tip Mr. Skittles gave before he returned to the year he came from is that Future Armour can also be used as a wheel wax; how easy is that!
| Product number | DJFA500 |
| Consistency | Liquid |
| Durability | Medium |
| Gloss Level of Surface | Glossy |
| Product form | Spraybottle |
| To be applied wet | Yes |
| Type of protection | Synthetic (sealant) |
Wet Use:
- After washing and rinsing, mist onto the still damp paint
- Immediately rinse off with a pressure washer
- Then dry.
- Work panel by panel and do not let it dry.
Dry Use:
- Apply using a microfiber pad or cloth
- Immediately buff
- Do not let it dry.
* Note when dealing with damaged or old paintwork. Always test first in an inconspicuous area.
Fijne spray
Fijne spray met schitterende beading. Denk dat je al snel te veel gebruikt aangezien 20ml per auto wordt aanbevolen. Laat op de ruiten wel een vervelende waas achter maar je kan ook niet voorkomen dat het product daarop terecht komt bij het afspoelen. De volgende keer ga ik de ruiten altijd nabehandelen met een reiniger, dit vind ik nu te storend
Prima Spul
Gemakkelijk en snel aan te brengen, lak wordt mooi glad, mooie parelvorming bij regen
Standtijd kan ik nog niks over zeggen, maar nu na 3 natte weken nog steeds mooie parelvorming na een bui
Mijn ervaring op glas is echter niet zo positief...laat vettige laag/waas achter, dus op glas doe ik het niet meer
Fijn spul
Ik heb een sample besteld voor m'n fiets en motorfietsen. Ben zeer tevreden. Het pompje spuiit mooi gericht en de lak glimt als een spiegel.
Volgens het etiket moet het 24 uur "curen", ik denk niet dat ik het voor de auto ga gebruiken, want die staat buiten.
