Future Armour High Performance Spray Sealant - 500ml
Art. nr. DJFA500
5.0 (22)
Future Armour is a technologically advanced spray sealant that has the advantage of being water-based. This means you can use the product on both dry and wet paints, or even as a wingman while rinsing with a pressure washer.
As the name suggests, Future Armour is a technological marvel with one foot in the future. Dodo Juice has received a visit from Mr. Skittles from the year 2039, who has shared all the secrets.
According to Mr. Skittles, there will always be fans of Red Mist because the shine this spray provides is legendary (both now and in the future), but the formula of this product will deliver great results for a fraction of the price, and thanks to the water-based formula, this product is as versatile as it gets.
In fact, “versatile” doesn’t even begin to cover it. Future Armour can be used on paint, plastic, glass, and even metal. Both wet and dry. Use it as standalone protection or as a boost to your wax or sealant.
You can use the product neat, but because it is water-based, you can also dilute it up to 1:10 depending on personal preference. Of course, the product will lose some of its performance after dilution, but with regular use, you’ll hardly notice it. The chance of streaks will be significantly lower with diluted use.
Do you have a foam lance? You can also use Future Armour with it. But be aware that the mesh filter can get clogged more quickly, so always make sure to have a spare filter on hand.
Does it look like rain🌧️ is coming? Preferably wipe the product off with a microfiber cloth so that the rain doesn’t run the product further over your car, causing streaks. Nobody likes that.
The last tip Mr. Skittles gave before he returned to the year he came from is that Future Armour can also be used as a wheel wax; how easy is that!
Product number DJFA500
Consistency Liquid
Durability Medium
Gloss Level of Surface Glossy
Product form Spraybottle
To be applied wet Yes
Volume Medium (401ml - 750ml)
Wet Use:
  • After washing and rinsing, mist onto the still damp paint
  • Immediately rinse off with a pressure washer
  • Then dry.
  • Work panel by panel and do not let it dry.
Dry Use:
  • Apply using a microfiber pad or cloth
  • Immediately buff
  • Do not let it dry.
* Note when dealing with damaged or old paintwork. Always test first in an inconspicuous area.
Dodo Juice Ltd
Oak Industrial Park 14
H
Boven verwachting
Erg makkelijk op te brengen en te verwijderen. Ik breng het zelf op een natte , gewassen en afgespoelde auto aan. Mooie beading, Prachtig resultaat, blijvertje!
Bert - 6 December 2020
Super spul
Al regelmatig gebruikt op verschillende auto 's, soms als topping op een harde wax, soms enkelvoudig.
Standtijd zeker 3 weken als topping, enkelvoudig na 3 maanden nog wat beading Verwerkt supermakkelijk.
Lucas - 27 June 2020
Diepe glans goede bescherming
Na snel verwerken op natte auto na in nevelen op een natte auto daarna inwrijven met microvezel doek na spoelen met glansdroger ultiem resultaat
Let op!! Wel gebruikt op een auto die 3 stappen gepolijst is en behandelt is met dodo juice banana armour hard wax
Na elke wasbeurt gebruiken en je auto blijft een diepe glans houden
Rick - 3 May 2020
Dodo Juice
Royal Plush Edgeless Buffing Cloths - 30x30cm
  • Zachte microvezeldoek
  • Handzaam formaat
  • Perfect voor licht werk
  • Randloos ontwerp
€ 15.49
Carclean.com
Fluxx tapkraan 13/51 DIN 51
  • Probleemloos vullen
  • Geen geknoei
€ 5.49
Dodo Juice
Future Armour High Performance Spray Sealant - 5000ml
€ 73.49
Dodo Juice
€ 15.99
Favorite
Q²M Wetcoat
  • Langdurig resultaat
  • Gemakkelijk in gebruik
€ 16.99
Offer
Acquafobia Spray Coating
  • Easy to use spraycoating
  • Sustainable up to 12 weeks
  • Extremely water repellent
Retail price: € 16,- € 14,-
