Detail Wheel Brush Mini
Art. nr. EZ-Mini
4.4 (105)
EZ Detail Mini Brush - The specialist for tight spaces
The EZ Detail Mini Brush is a more compact version of the well-known large EZ Detail brush, specifically designed for cleaning areas with limited space. This brush is perfectly suited for wheels with many spokes, complex patterns, engine bays, exhaust tips, and grilles. Thanks to the flexible stem, the brush can be bent into various angles to reach the back of spokes or brake calipers.
The bristles are made of soft Nylex nylon, ensuring safe cleaning without scratching paint or chrome finishes. The bristles are resistant to harsh chemicals and do not permanently deform; heat helps them return to their original state. Both the tip of the brush and the handle feature rubber guards to prevent accidental damage during use.
Product number EZ-Mini
Additional features Buigbaar
Made from material Nylon/Memory-Nylex
Size Small
    1. Mix a wheel cleaner or car shampoo with water in a bucket.
    2. Immerse the brush in the soapy water to ensure proper lubrication.
    3. Gently move the brush between spokes and into wheel barrels.
    4. Rinse the brush frequently in the bucket to release trapped dirt.
    5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
    6. Hang the brush to dry; the bristles will regain their original shape.
    Tips
    • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
    • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Ondanks de spetters 5 sterren
Ja de borstel structuur doet spetteren bij het heen en weer raggen. Maar ondanks het forse vormvast past het prima ook tussen de kleinere openingen wat ik niet had verwacht. Ik vond dit vele malen beter dan een microvezel borstel gezien het ook beter om
De hoekjes gaat. Voor mij een dikke 10 maar dat zal ook wel per type velg afhangen. Ik rij een Kia Ceed en past probleemloos in alle openingen
Sebastian - 8 February 2026
Goede kwaliteit
Gekocht voor de lastig bereikbare plekken. Past helaas - in mijn geval - nog altijd niet tussen remklauw en velg. Voor de rest een prima borstel met zachte haren en merkbare kwaliteit!
Ivo - 30 January 2026
Geweldig
Ze zijn goedkoper geworden dan een paar jaar terug. Dat is nou nog eens top. Zet niet teveel druk en dan heb je er lang plezier van.
Joël - 24 December 2025
