Detail Wheel Brush Mini
EZ Detail Mini Brush - The specialist for tight spaces
The EZ Detail Mini Brush is a more compact version of the well-known large EZ Detail brush, specifically designed for cleaning areas with limited space. This brush is perfectly suited for wheels with many spokes, complex patterns, engine bays, exhaust tips, and grilles. Thanks to the flexible stem, the brush can be bent into various angles to reach the back of spokes or brake calipers.
The bristles are made of soft Nylex nylon, ensuring safe cleaning without scratching paint or chrome finishes. The bristles are resistant to harsh chemicals and do not permanently deform; heat helps them return to their original state. Both the tip of the brush and the handle feature rubber guards to prevent accidental damage during use.
| Product number | EZ-Mini |
| Additional features | Buigbaar |
| Made from material | Nylon/Memory-Nylex |
| Size | Small |
Mix a wheel cleaner or car shampoo with water in a bucket.
Immerse the brush in the soapy water to ensure proper lubrication.
Gently move the brush between spokes and into wheel barrels.
Rinse the brush frequently in the bucket to release trapped dirt.
Thoroughly rinse both the surface and the brush with clean water after cleaning.
Hang the brush to dry; the bristles will regain their original shape.
Tips
Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Doet wat het moet doen
Werkt goed, alleen door de haren spetterd die heel veel.
Top borstel
Ik heb de borstel aangeschaft nadat ik het in werking heb gezien bij het kanaal van Frisvoordedeur.
Had eerst een andere velgenborstel. Deze was stugger.
De EZ detail mini Brush Small is perfect voor mijn velgen. Heb kleine velgen, maar ondanks dat past de borstel tussen de spleetjes waar ik met de hand niet bij kan. De haren zijn niet hard dus beter voor de velg.
Alleen het gedeelte bij het remblok past de borstel niet tussen. Maar dat komt doordat de velgen niet groot zijn.
Deze borstel is een aanrader. Mocht ik m moeten vervangen, dan wordt het zeker weer deze borstel. Een echte aanrader!
Super fijne borstel
Tot nu toe gebruikte ik minder goede velgenborstels waaronder de microvezelvarianten maar met deze borstel kun je makkelijk overal bij komen en hij reinigt grondig. Super fijn en als je hem na gebruik afspuit en afdroogt, blijft hij ook mooi.
