Detail Wheel Brush Mini
EZ Detail Mini Brush - The specialist for tight spaces
The EZ Detail Mini Brush is a more compact version of the well-known large EZ Detail brush, specifically designed for cleaning areas with limited space. This brush is perfectly suited for wheels with many spokes, complex patterns, engine bays, exhaust tips, and grilles. Thanks to the flexible stem, the brush can be bent into various angles to reach the back of spokes or brake calipers.
The bristles are made of soft Nylex nylon, ensuring safe cleaning without scratching paint or chrome finishes. The bristles are resistant to harsh chemicals and do not permanently deform; heat helps them return to their original state. Both the tip of the brush and the handle feature rubber guards to prevent accidental damage during use.
| Product number | EZ-Mini |
| Additional features | Buigbaar |
| Made from material | Nylon/Memory-Nylex |
| Size | Small |
Mix a wheel cleaner or car shampoo with water in a bucket.
Immerse the brush in the soapy water to ensure proper lubrication.
Gently move the brush between spokes and into wheel barrels.
Rinse the brush frequently in the bucket to release trapped dirt.
Thoroughly rinse both the surface and the brush with clean water after cleaning.
Hang the brush to dry; the bristles will regain their original shape.
Tips
Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Blijft toch de topper
Heb de large variant, en dat blijft toch de beste borstel, om overal tussen te komen. Hij spettert graag, maar daar kun je je werkwijze op aanpassen (rustig uit de velg halen).
Veel beter inzetbaar dan de dikke logge microvezel varianten als je het mij vraagt... De beste allrounder!
De beste allround velgenborstel
Ik heb de grote variant al jaren en blijf er bij terugkomen, ook na het uitproberen van wat 'moderne' vezel-varianten. Die dikke/stugge borstels komen lang niet overal tussen, en dan moet je er toch weer een kleine versie bij hebben die vervolgens te kort, te dun of te dik blijkt. Deze (grote) EZ Detail Auto Brush komt overal tussen en is ook lang genoeg voor brede velgen. Het enige nadeel: hij spettert best graag in jouw richting (mijn reden om andere borstels te gaan proberen). Zolang je niet gaat detailen in je goeie goed is er op zich weinig aan de hand, en deze doet tenminste wel gewoon alles. Voor de voorkant gebruik ik een wheelmitt tussen de spaken en voor het velgbed de EZ Detail. Meer heb je niet nodig. 👍
Handige velgenborstel!
Ik heb de kleine versie van deze borstel en die bevalt mij uitstekend! Het borsteltje is dun en past daardoor makkelijk door de kleine kieren van mijn Alfa-velgen. Het handvat dwingt je om niet te drukken en te schrobben, waardoor je de borstelharen het werk laat doen. Voor het vuil in de randjes blijf ik wel een kwastje gebruiken. Bij levering waren die borstelharen wat verbogen, maar even onderdompelen in warm water en de haren staan weer in de juiste richting.
